the trannys in hemi rams, and cars #1650557
07/24/14 07:24 PM
07/24/14 07:24 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
Are they usable in high performance applications at all? I would think the LX and truck guys arent swapping in 727s in their cars
Re: the trannys in hemi rams, and cars [Re: sixpackgut] #1650558
07/24/14 08:12 PM
07/24/14 08:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If your talking putting one behind your engine you
need to get the hyd version... NOT the electric version
(the hyd version has 1 pin or 3 pins on the electric
plug, not the NSS plug).. then change out the input
shaft so you can use a high stall conv... if guys
are using the lock up version they put a spacer behind
the engine so they can put a thicker conv in.. the
conv with a decent stall and lock up cost about $1800 and up
EDIT
you need too change the pump gears or the pump assm
to match the 727 conv if you go non lock up
Re: the trannys in hemi rams, and cars [Re: MR_P_BODY] #1650559
07/24/14 10:29 PM
07/24/14 10:29 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The LX car NAG1 seems stout to around the 1000hp mark but much beyond that they seem to go th400. The truck trans are decent to about 500hp but overall they suck. PCS just came out with standalone NAG1 ecu. The only reason you don't see more nag1 swaps is because of lack of controllers.
Mopar to the bone!!!
Re: the trannys in hemi rams, and cars [Re: 72Swinger] #1650560
07/25/14 01:58 PM
07/25/14 01:58 PM
Charleston
Charleston
I didn't know they were different. hhmmm
Re: the trannys in hemi rams, and cars [Re: sixpackgut] #1650561
07/25/14 02:39 PM
07/25/14 02:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The NAG1 (New Automatic Gearbox Generation 1)
Re: the trannys in hemi rams, and cars [Re: John_Kunkel] #1650562
07/25/14 09:55 PM
07/25/14 09:55 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
Otherwise known as a Mercedes 722.6.
The HEMIs usually will run a 45RFE/545RFE, same unit, just one is programmed for 4 speeds, one for 5.
Pat
" The last official act of any goverment, is to loot the treasury" George Washington
Re: the trannys in hemi rams, and cars [Re: zzyzxpat] #1650563
07/25/14 10:18 PM
07/25/14 10:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I call the NAG trannys the female trans. Ron
Re: the trannys in hemi rams, and cars [Re: 383man] #1650564
07/26/14 01:35 AM
07/26/14 01:35 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I love the one in my SRT Challenger. Once I installed a cooler thermostat and the trans fluid ran 25 degrees cooler,it will HIT nice on the first three shifts.
I would put on behind stroker big block in a second
Re: the trannys in hemi rams, and cars [Re: zzyzxpat] #1650565
07/26/14 10:28 AM
07/26/14 10:28 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I believe this is the same trans my friend has in his twin turbo v12 mercedes
Re: the trannys in hemi rams, and cars [Re: John_Kunkel] #1650566
07/26/14 11:02 AM
07/26/14 11:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I assume someone make a different output shaft so you
can get rid of of the rubber coupler and can go to a
slip yoke... what does that nagy weigh
Re: the trannys in hemi rams, and cars [Re: MR_P_BODY] #1650567
07/27/14 05:45 PM
07/27/14 05:45 PM
MN
hemidup Offline
hemidup  Offline
MN
I've built them both and wouldn't use either in a race application because of the gear ratio's, converter choices, parasitic drag and/or weight. Street use is fine.
The 545 comes in with a dry weight of a 175lbs and the 722.6 right around the same weight as a 727.
I run a 545 in my truck and rebuild it every 100 passes or if and when the clutches burn up before that.
Jerry Williams.
Re: the trannys in hemi rams, and cars [Re: hemidup] #1650568
07/27/14 05:55 PM
07/27/14 05:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 518 weighs a big 147.. what a 727.. its got to
be right at a 100 lbs or a bit more... I know the
OD and tail shaft assembly feel pretty heavy
Re: the trannys in hemi rams, and cars [Re: MR_P_BODY] #1650569
07/27/14 06:17 PM
07/27/14 06:17 PM
MN
hemidup Offline
hemidup  Offline
MN
I took a bare 727, 904, 833 iron case, T56 and a 722.6 and weighed them side by side a few years ago. If my memory serves me right the 722.6 was within a few pounds of the 727. + or - I can't remember but I do believe heavier and a 115lbs rings a bell but I'd have to check my old notes to be sure. My memory just has to remember where I put them now.
Jerry Williams.
Re: the trannys in hemi rams, and cars [Re: MR_P_BODY] #1650570
07/27/14 06:21 PM
07/27/14 06:21 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
There isn't any room on the NAG1 as there is no extension housing and the park gear rides in the very back of the case, not to mention that you would have to fabricate a different output shaft as they have never been made with a slipyoke. All Mercedes transmissions use a bolt on yoke.
Pat
Re: the trannys in hemi rams, and cars [Re: zzyzxpat] #1650571
07/27/14 06:26 PM
07/27/14 06:26 PM
MN
hemidup Offline
hemidup  Offline
MN
Pat
Wonder if you could take a 722 from an AWD, remove the transfer case adapter and then make up a tail shaft housing to support a slip yoke
Jerry Williams.
Re: the trannys in hemi rams, and cars [Re: hemidup] #1650572
07/27/14 06:49 PM
07/27/14 06:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I figured if the trans is any good that someone would
have built a output shaft and a tail shaft for it
to utilize a slip yoke.. but looking at the 2 WD there
isnt a bolting point at the rear so I guess it would
have to be the AWD version
Re: the trannys in hemi rams, and cars [Re: MR_P_BODY] #1650573
07/27/14 08:26 PM
07/27/14 08:26 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
I don't have any technical input, but I do recall my cousin having numerous issues with the trans in his '04 Ram Daytona. He couldn't even get home from the transmission shop without toasting something in the transmission. It put down something like 500hp at the wheels with a Procharger and other mods. He ended up taking the supercharger off just so he could drive the truck without breaking it.
Re: the trannys in hemi rams, and cars [Re: hemidup] #1650574
07/27/14 11:35 PM
07/27/14 11:35 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
Pat
Even the AWD are bolt on yoke, they use a coupler that bolts on to the output shaft.
Pat
