hemi inner studs protruding into port.... #1650477
07/24/14 04:45 PM
07/24/14 04:45 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
I have to put together two street hemis here and the mopar perf headbolt kit,inner studs ,protrude a fair bit into the intake ports.should I grind these down? the heads are built and assembled so I don't really want to start grinding in there although I could thread the studs into a spare head,grind em and then put them into the heads Im using or should I even bother?
Ive got an arp kit here and those studs sit shallow in the port,leaving a hole .
Id swear a couple of the studs and head bolts in the mopar kit appear bent too........
Re: hemi inner studs protruding into port.... [Re: ogopogo] #1650478
07/24/14 04:54 PM
07/24/14 04:54 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
It depends on if you care how much power the Hemi makes. If you care, take them out and grind them down flush with the port floor. It's pretty easy to do.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: hemi inner studs protruding into port.... [Re: ogopogo] #1650479
07/24/14 04:59 PM
07/24/14 04:59 PM
Remove the long ones and grind them down flush like HemiJoel suggest On the ARP studs use a good epoxy sealer to fill in the holes, make sure and use a good thread sealer on both sets
Re: hemi inner studs protruding into port.... [Re: Cab_Burge] #1650480
07/24/14 05:06 PM
07/24/14 05:06 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
Yeah,im going to pull them and shorten them.Was planning on using some indian head shellac to seal them.....
Re: hemi inner studs protruding into port.... [Re: ogopogo] #1650481
07/24/14 07:50 PM
07/24/14 07:50 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Don't want to hijack this thread but my arp studs are not long enough for the nut and the washer(very little in the head). do they make different lengths? decks been milled .0125
Re: hemi inner studs protruding into port.... [Re: cudaman1969] #1650482
07/24/14 09:24 PM
07/24/14 09:24 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Yes. Different manufacturer heads require different lengths.
For example ARP-245-4312 is just the 7/16 valley studs for World blocks (tad longer)
Re: hemi inner studs protruding into port.... [Re: Mopar_Rich] #1650483
07/25/14 12:54 AM
07/25/14 12:54 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
stock block and stock heads and the other studs-nuts are long enough, the studs are screwed all the way in right?
