Re: hemi inner studs protruding into port....
[Re: ogopogo]
#1650478
07/24/14 04:54 PM
07/24/14 04:54 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
It depends on if you care how much power the Hemi makes. If you care, take them out and grind them down flush with the port floor. It's pretty easy to do.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Mopar_Rich]
#1650483
07/25/14 12:54 AM
07/25/14 12:54 AM
Posts: 8,250 fredericksburg,va
cudaman1969
fredericksburg,va
Don't want to hijack this thread but my arp studs are not long enough for the nut and the washer(very little in the head). do they make different lengths? decks been milled .0125
Yes. Different manufacturer heads require different lengths. For example ARP-245-4312 is just the 7/16 valley studs for World blocks (tad longer)
stock block and stock heads and the other studs-nuts are long enough, the studs are screwed all the way in right?
