Painless has a deal for a racer! #165029
12/09/08 05:45 PM
12/09/08 05:45 PM
Arlington, Tx.
BJS racing Offline OP
Arlington, Tx.
We are just finishing up our 50005 8 circuit race harness. Here's the fun part. Someone will get a free one. But, yes theres a but, we will give you the harness only if it can be installed and give us feed back by christmas. Now most of you guys know me personally or through the board here. If you go to the link below you can see a pic of the set up that you will be getting for your feed back and install feed back on our newest product. I originally designed this set up for guys like us. It is EVERYTHING you need to wire your race car. The only thing you would need to make it a street car would be our 30120 turn signal kit. I have to have someone picked out for this install by thursday. So PM me with your info and I'll let you know all the requirements.
Jason Hamner
Painless Performance
Tech. Support
Back in the swing of things at Painless again! Great to be back!
Re: Painless has a deal for a racer! [Re: BJS racing] #165030
12/09/08 05:48 PM
12/09/08 05:48 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Jason, linky missing!!!
Re: Painless has a deal for a racer! [Re: Blucuda413] #165031
12/09/08 05:53 PM
12/09/08 05:53 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
And my car already has one of your 8 circuit kits
Maybe if I wasn't so sick of working on it from this past season
Re: Painless has a deal for a racer! [Re: Blucuda413] #165032
12/09/08 05:56 PM
12/09/08 05:56 PM
Arlington, Tx.
Arlington, Tx.
Yeah I was just coming back to do that. Things move quick guys. Mopartony is actually going to be doing the install. But here is the link to the harness and switch panel on our site.
http://www.painlessperformance.com/webcatalog/Keywordsearch.php?partsearch=50005
Re: Painless has a deal for a racer! [Re: BJS racing] #165033
12/09/08 06:37 PM
12/09/08 06:37 PM
Arlington, Tx.
Arlington, Tx.
Oh and btw this is the only place I posted this up on. It was going to go to one of you guys or noone!
Re: Painless has a deal for a racer! [Re: BJS racing] #165034
12/09/08 07:03 PM
12/09/08 07:03 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Me,Me Pick Me
Re: Painless has a deal for a racer! [Re: B G Racing] #165035
12/09/08 09:51 PM
12/09/08 09:51 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
i might have a bracket dakota that needs one in my dads truck. i will ask him. i would have to have it installed by the 24th because we would be living then for my in-laws. we test fitted the musclecar kit on his hemi dart when that kit came out a few years ago.
justin
ps i am still working on coming to texas to see a "real" install
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: Painless has a deal for a racer! [Re: B G Racing] #165036
12/09/08 09:57 PM
12/09/08 09:57 PM
Georgetown, TX
sc4579 Offline
sc4579  Offline
Georgetown, TX
I already did one of those Jason over a year ago in my other Dart Sport I sold to Jake Pitt. It was an 8 circuit switch panel and 8 switch in dash panel. Turned out real nice and only took me most of a Sunday to do it. Here is a pic of it in the dash, did not take one of the fuse/relay panel under the dash. Kim
2023 Challenger Scat Pack 1320
2016 Jeep Renegade
Re: Painless has a deal for a racer! [Re: sc4579] #165037
12/09/08 10:26 PM
12/09/08 10:26 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
I like the new switches. I saw the panel at SEMA and knew that was going to go into my car
I saw in your catalog that you also have an 8 switch box with the new switches. Will that be available as a kit with the harness as well, or can you only get the 6 switch panel with the harness???
Re: Painless has a deal for a racer! [Re: BJS racing] #165038
12/09/08 10:30 PM
12/09/08 10:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well I was thinking of redoing all of my electrical
and if Tony is doing the install, he's close to me
a couple of miles
Re: Painless has a deal for a racer! [Re: wldtm] #165039
12/09/08 10:36 PM
12/09/08 10:36 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
justin
jason, i would be interested in installing this between the 20th and 24th of decemeber. engine is about finished being assembled, but would not be installed. but i could test all circuits if need be. thanks for the offer to us moparts members
justin
Re: Painless has a deal for a racer! [Re: wldtm] #165040
12/09/08 10:46 PM
12/09/08 10:46 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
Jason, I have the same painless switch set up that SC4579 has in his above picture. I took this unit out of a wrecked race car and need the box for it that makes it a rollbar mount. Do you sell those individually?
thanks, Keith
Re: Painless has a deal for a racer! [Re: PolyDart] #165041
12/11/08 09:49 AM
12/11/08 09:49 AM
Arlington, Tx.
Arlington, Tx.
The kit that I'm showing is only set up for the 6 switch panel. If you wanted to do an 8 switch set up you would use what Kim used. The 50202 and the 50001 part numbers. The one I designed (50005) was so that it could more easily fit in a dragster or small cockpit car as well as full bodied race cars and give you an additional relay for use with either a line lock or trans. brake. If you notice there will be a lot of delay box manufaturers that will tell you it may be necissary to use a relay to get the trans. brake to work properly. I took all the problems I've run across wiring race cars and put it into this kit to hopefully give everything needed for just about any level of a racer.
Re: Painless has a deal for a racer! [Re: Keith Richards] #165042
12/11/08 09:50 AM
12/11/08 09:50 AM
Arlington, Tx.
Arlington, Tx.
thanks, Keith
You have a pm!
Re: Painless has a deal for a racer! [Re: BJS racing] #165043
12/11/08 10:10 AM
12/11/08 10:10 AM
Windsor ,Ca.
K
K
Windsor ,Ca.
thanks, Keith
You have a pm!
Jason, Thanks for taking care of me! Keith
Re: Painless has a deal for a racer! [Re: Keith Richards] #165044
12/11/08 01:03 PM
12/11/08 01:03 PM
Arlington, Tx.
Arlington, Tx.
Well everyone, the decision was made (of course after I posted this) that they are not going to do a pre release install. Thanks for all your reply's. Sorry about the outcome. But they will be available for sale in about a week or two through any of our dealers.
Jason
Re: Painless has a deal for a racer! [Re: BJS racing] #165045
12/11/08 03:56 PM
12/11/08 03:56 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Great!! Now I have speghetti on my garage floor!!!
Just kidding. Jason thanks for thinking of my on this.
I am thinking I will want to try one of these harnesses. We have talked about the issues in the Duster.
What does one of these little gems run cost wise?
Re: Painless has a deal for a racer! [Re: mopartony] #165046
12/11/08 04:37 PM
12/11/08 04:37 PM
Arlington, Tx.
Arlington, Tx.
Well its your fault you have spaghetti on your floor. Your a messy eater man!
List on the harness is $999.95. So you will more than likely see it at somewhere around $750 through most of the dealers. If you price a switch panel and a 50001 it actually comes out a little cheaper and is set up a little better.
Re: Painless has a deal for a racer! [Re: BJS racing] #165047
12/11/08 04:42 PM
12/11/08 04:42 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Yeah I guess I should not eat in the garage.
a grand, ouch a little pricey for me. It may have to wait and I will have to dive in and see if there is an issue or if the driver/owner is just parinoid.
Re: Painless has a deal for a racer! [Re: mopartony] #165048
12/11/08 04:52 PM
12/11/08 04:52 PM
Arlington, Tx.
Arlington, Tx.
Man like I said. That is list! I don't know anyone that pays list. That is unless your one of those stubborn bastards that has to get it directly from the manufacturer. Typically the end user will pay Jobber or just a touch over Jober which is where the $750ish price came from. But think about what you spent on what you have there now and you'll notice its not a whole lot more!
