MSD 6AL help / 66 Coronet
#1650285
07/24/14 12:12 AM
07/24/14 12:12 AM
Posts: 267 Santa Clara , ca
ramcuda
Santa Clara , ca
after an few hours of killing myself ...
Im working on a 66 Coronet that was changed over to the DC/Mopar Electronic..that is eating ballast resisters..So we are going over to a MSD 6AL set up...
How are any of you hooking up the power wire that turns the box on and off ( key on / Key off ) without using a toggle switch ? I have tired connecting to (ING 1 side ) 12volts only during key on..
If you hook up the MSD box per the is wire diagram .. it tells you to hook it to the old coil on the pos side ( ING 2 side power during starting )...
doesnt work .. when you let off the key it drops the 12volts off that wire...as well
there no true key on power on the fuse box..same thing there turn the key to crank the motor and the fuse box drops the 12volt ...
Im sure its me going wrong...
thanks all ...
1965 Ply "RAMCUDA" got to see it!!!<--- Should sell it/ 1970 Superbird <------ Just one big argument/ 1980 Jeep CJ5 <--- Just wheel it/ 2000 Dakota R/T <--- Should Drive it more/ 2001 Dodge Caravan <----- Cant kill it/ 2004 Dodge 2500 4dr DIZLE 4x4 <---- LOVE IT !!! www.moparalley.org
Re: MSD 6AL help / 66 Coronet
[Re: ramcuda]
#1650287
07/24/14 12:23 AM
07/24/14 12:23 AM
Posts: 3,424 Portland Oregon
69Dartman
Portland Oregon
The manual should be available online and they more then likely have a forum that can help figure it out as well. I tried several of those in my Dart and could never get one to run longer then 6 months what with the crappy wiring and my luck so I gave up. They even rebuilt two for free and still no luck.
Life's a little bit better when you hit a Camaro.
[Re: 69Dartman]
#1650288
07/24/14 12:56 AM
07/24/14 12:56 AM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I had the exact same problem back in 2006. I don't have my book handy to get more detail, but i remember that there is 2 ign wires coming of the ignition switch. One is hot only during cranking, the other is hot anytime the key is on. You have connected the MSD to the wrong wire.
Edit: I found a wiring diagram. If you hook the msd to the brown wire, you have this problem. Hook it to the dark blue with a stripe wire. Good luck, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#1650289
07/24/14 01:17 AM
07/24/14 01:17 AM
ramcuda
Santa Clara , ca
dark blue w/yellow trace ,,,ya thats (ING 1) when you turn the key to start the 12 volts drops from that wire ...
[Re: ramcuda]
#1650292
07/24/14 01:26 AM
07/24/14 01:26 AM
Posts: 516 ND
dodgedon
ND
Are you useing a ballast? You dont need it. I made a dummy Ballast that lets the voltage flow through it. Same as if the two ballast wires were hooked together.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: dodgedon]
#1650293
07/24/14 01:33 AM
07/24/14 01:33 AM
ramcuda
Santa Clara , ca
yes the ballest is there ... i did tie both wires together(unhooked from the ballest) but.. when i did the split sec where there is no power on ether wire it was enough that the box powered down and stop running,,,
[Re: ramcuda]
#1650294
07/24/14 09:10 AM
07/24/14 09:10 AM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
One IGN wire is supplying voltage ONLY when running (not cranking), the other is supplying voltage when cranking, and this circuit jumps the old ballast resistor and supplies a full 12v to the coil when cranking to help with starting.
You need to tie both of this circuits from the switch to the 12v key /switch input to the box. One will enable the ignition when cranking, and the other will when switch is in run position.
I'm not sure the color codes are the same for a Dart, but I can look when I get home (much) later today....
383, Hemi 4-Speed, AlterKtion, D60
[Re: Crazy68Dart]
#1650295
07/24/14 09:14 AM
07/24/14 09:14 AM
Crazy68Dart
Canton, Ohio
How do you have the box wired otherwise? Which coil? Ballast resistor should not be needed assuming you are running a Blaster 2 coil with your box.
[Re: ramcuda]
#1650296
07/24/14 10:41 AM
07/24/14 10:41 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
I have my red 12v feed for my MSD hooked to the ballast resistor with the dual-wire lead/plug. I had problems just like this. I thought I had a good 12v source ( which I did ), but with the key in IGN2 when cranking, the 12v was interrupted on the single wire side of the ballast. So, I swapped it around after some mentoring here on moparts and voila, it worked. I too have replaced the coil resistor of the ballast resistor with a straight gauge-appropriate wire, 12v in, 12v out.......
Attached is a picture of the engine bay, you'll see where my 12v feed it placed on the one side of the ballast resistor. I just used a "T" adaptor.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#1650297
07/24/14 10:56 AM
07/24/14 10:56 AM
Posts: 5,166 CT
GTX MATT
CT
The wires that connect to the ballast resistor need to be making a connection, whether they're spliced together, or connected to a gutted ballast, or the ballast is in place.
My 12v key operated source is the original coil positive like the instructions say to do, and I took my ballast resistor apart and soldiered a wire between the two terminals, then filled with epoxy.
[Re: 383man]
#1650299
07/24/14 06:41 PM
07/24/14 06:41 PM
hemi68charger
Houston, Tx
The MSD needs to be hooked to both the 12 volt run and 12 volt start circuits (ign 1 & ign 2) and the easiest way to do it is just hook your old coil + wire to the MSD run circuit and then jump the ballast together. Then you have 12 volts in run and 12 volts when cranking. The 12 volt bypass while cranking is still there but its just not bypassing the ballast as you dont need the ballast with the MSD so the 12 volt crank circuit lets it start while cranking. Ron
That is nice..... So, now I can actually put the blue wire to something, the + post of my MSD Blaster coil....
