Aluminum axle housing 9" #1649988
07/23/14 09:48 AM
07/23/14 09:48 AM
Finland, Europe
Ck[FIN] Offline OP
Ck[FIN]  Offline OP
Finland, Europe
http://www.ebay.com/itm/141328571636
Anybody have experience with this? How much power it can handle?
I was thinking to upgrade my leaf spring 8 3/4 to 4-link 9" next winter and came up with this. Or should i still continue to search from racingjunk
-1965 Valiant 9.03s 358cu.in R5P7-
Re: Aluminum axle housing 9" [Re: Ck[FIN]] #1649989
07/23/14 09:55 AM
07/23/14 09:55 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Think I'd just go with a Fab 9 housing.
Re: Aluminum axle housing 9" [Re: Ck[FIN]] #1649990
07/23/14 09:56 AM
07/23/14 09:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a alum 9" here but I never put it in anything
so I cant say what this will take for power
EDIT
Mine is different from the one posted.. my axle tubes
arent bolt on.. mine are steel tubes that looked to
be pressed in with screws or bolts just into the tubes...
the ends are cut off on mine but it looks like I can
just weld ends on... the one thing I dont like about
the one shown OR mine is how to back brace it, with
steel tubes and a alum center... the best I can figure
out is to weld the brace to the tubes and bolt to the center
Re: Aluminum axle housing 9" [Re: Ck[FIN]] #1649991
07/23/14 10:44 AM
07/23/14 10:44 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That is very interesting. It looks to be a center casting, I when I opened the link thought I would find a welded fabricated item. To be clear, this is a 9" housing, not the center section. I wonder what the weight savings could be over say CM? It says 35% stronger? I give a for effort. If it is a casting likely will never see a similar alum 8.75 version, but they are hated around here anyway.
Re: Aluminum axle housing 9" [Re: jcc] #1649992
07/23/14 11:12 AM
07/23/14 11:12 AM
washington
Bruce Offline
Bruce  Offline
washington
I did a search for the TDS housing and found a post on fordmuscleforums. The housing is sold through Procomp Electronics in the "Speedmaster" division. Here is a link to it.
http://store.speedmaster79.com/p-3860-ford-9-modular-differential-housing-section.aspx
Personally, I wouldn't buy it, since it is a casting for an area that gets high stress and it no doubt comes from China. Plus bolting on axles housings just gives you one more place for it to come apart and one more thing to check to be sure it isn't coming loose. It would probably work fine in a light weight roadster or something similar.
Just my
Re: Aluminum axle housing 9" [Re: Ck[FIN]] #1649993
07/23/14 11:59 AM
07/23/14 11:59 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Although this isn't the same housing it is similar in design. The writer makes some good points of observation.
http://www.racingjunk.com/news/2014/05/01/star-wars-axle-housings-part-iv-aluminum-modular-housings/
I don't remember who made those early magnesium Dana 60 housings but I think if it was a sound design we would have seen more of them at the track
Gus
64 Plymouth Savoy
Dana 60
Re: Aluminum axle housing 9" [Re: jcc] #1649994
07/23/14 12:05 PM
07/23/14 12:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I hear ya but they`re generally hated by those who can`t make em live or those who see faster guys that DO make em live...........
Re: Aluminum axle housing 9" [Re: MR_P_BODY] #1649995
07/23/14 01:31 PM
07/23/14 01:31 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Mr P it sounds like you have one of the Winters housing centers. I also have one that I'm working on. To add additional strength I designed my own brackets wherby I can add 1" tubing between the steel axle tubes both on the top and on the bottom. I haven't finished mine yet but I'm getting close. I'm just about ready to pull the axle tubes into the alum housing. I bought mine years ago but before I did I talked to several people who were using them in a drag car. One guy said he was using his behind a 950hp engine with no additional bracing and had no problem whatsoever. I put mopar ends on mine so I could reuse my rear brakes and my Strange 35 spline axles. Since my Ford spool had splines all the way through and my axles had long splined ends I did not have to buy new axles or have mine modified. I'm also using a Moser alum center section with a huge 10 bolt pinion support I found years ago. I'll probably never have more than 1000hp to work with. I'll probably have mine ready for next year.
Re: Aluminum axle housing 9" [Re: Thumperdart] #1649996
07/23/14 01:41 PM
07/23/14 01:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: Aluminum axle housing 9" [Re: Quicktree] #1649997
07/23/14 01:51 PM
07/23/14 01:51 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Nothing wrong with a properly braced and constructed alum housing. That is exactly what is under the fastest and baddest doorslammers on the planet...Pro-Mods. They all run Mark Williams modular alum housings..........Now that said, is the one in question comparable to a Mark Williams, hardly, but it could likely be made to work for many applications with properly braced tubes. But likely by the times you added the bracing and spent the time, you would be better off with a fabbed sheetmetal housing. This item strikes me as something that could be more "showy" or street rod designed, but appears to be primarily for circle track use
Monte
Re: Aluminum axle housing 9" [Re: Monte_Smith] #1649998
07/23/14 02:07 PM
07/23/14 02:07 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Strange Top Loaders are also aluminum rearends. Oh, but that's for dragsters, altereds, and funny cars.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Aluminum axle housing 9" [Re: Quicktree] #1649999
07/23/14 03:20 PM
07/23/14 03:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Why are you crazy quick? A few others and myself are living proof 8 3/4`s work well WHEN built properly.............nuff said homey...............
Re: Aluminum axle housing 9" [Re: Slingshot383] #1650000
07/23/14 03:24 PM
07/23/14 03:24 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Hmmmm,
Re: Aluminum axle housing 9" [Re: Thumperdart] #1650001
07/23/14 03:31 PM
07/23/14 03:31 PM
Q
Quicktree Offline
Quicktree  Offline
Q
when you get the street tires off, put a New set of real slicks on go to well prepped track and hook up you will then be living proof you have special 8-3/4 not before... And I was born
Re: Aluminum axle housing 9" [Re: Quicktree] #1650002
07/23/14 03:46 PM
07/23/14 03:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I still argue 1.36`s back to back at 3200 lbs. IS hooking and I`m on a 29x10.5 now so we`ll see AND you may be correct...........
Re: Aluminum axle housing 9" [Re: Thumperdart] #1650003
07/23/14 04:14 PM
07/23/14 04:14 PM
Q
Quicktree Offline
Quicktree  Offline
Q
i hope I am not, don't want to see you destroy your rear and tranny. If those slicks are used you may still ok, I was good up to a 11.5 slick. Then the carnage started.
Re: Aluminum axle housing 9" [Re: Quicktree] #1650004
07/23/14 04:16 PM
07/23/14 04:16 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
one good tire shake out of a decently horsepowered car and i have a feeling that housing will develop a few "leaks"
Re: Aluminum axle housing 9" [Re: GY3] #1650005
07/23/14 04:17 PM
07/23/14 04:17 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I am not sure it makes sense comparing the dragster track width above with what the OP pictured example track width the car is likely to be.
The Op picture shows a casting center with bolt on flanged axle tubes, what are and why the extra two bolted upper gussets, are they solving an unexpected weakness, or are mounting location for attachments, or?
Re: Aluminum axle housing 9" [Re: Quicktree] #1650006
07/23/14 05:07 PM
07/23/14 05:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I hear ya man and just like playing around and believe me, I don`t want to see it happen either............ I plan on an upgrade after my move and maybe 1 or 2 more passes.
Re: Aluminum axle housing 9" [Re: Thumperdart] #1650007
07/23/14 05:35 PM
07/23/14 05:35 PM
Finland, Europe
Ck[FIN] Offline OP
Ck[FIN]  Offline OP
Finland, Europe
Thanks for the replies. My 8 3/4 is not even backbraced and i have dozens of 9s runs, best so far 9.29s. I believe the 2850lbs weight and traction problems have saved the 8 3/4 so far. I hope it lives few more runs and then i can sell it to street use.
I`ll think i go with steel 9", it will be safer if i some day happen to have more power.
