Weight on flywheel? #1649846
07/22/14 08:13 PM
07/22/14 08:13 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Putting a 440source billet flywheel on my 318 going back in my car and I was wondering if I needed to leave the weight on it or take it off. The motor is a 74 318. I know the converter wasn't weighted but I'm new to manual trans stuff
Re: Weight on flywheel? [Re: SLOW67] #1649847
07/23/14 02:39 PM
07/23/14 02:39 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
i thought all 318's were neutral or zero balanced. i don't think there should be any extra weight on it.
Re: Weight on flywheel? [Re: joelson6] #1649848
07/23/14 05:25 PM
07/23/14 05:25 PM
dogdays Offline
dogdays  Offline
All 318s and 5.2 Magnums are neutral balanced.
If you have a "one-size-fits-all" flywheel, the extra weight(s) should be left off. There are four different amounts of imbalance: largest for 360, next for the 5.9 Mag, next for cast crank 383s, 400s and 440s, and smallest for the heavy rod 440s.
R.
Re: Weight on flywheel? [Re: dogdays] #1649849
07/23/14 06:34 PM
07/23/14 06:34 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Ill take it off then, I had to wait on a pilot bushing and it finally showed up today anyway so I'll take it off before it goes on. Thanks guys!
Re: Weight on flywheel? [Re: dogdays] #1649850
07/23/14 09:36 PM
07/23/14 09:36 PM
Socal
littleVAL Offline
littleVAL  Offline
Socal
Are the cast crank 340 a different balance as well
Re: Weight on flywheel? [Re: littleVAL] #1649851
07/23/14 09:47 PM
07/23/14 09:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
From the factory , yes
Re: Weight on flywheel? [Re: JohnRR] #1649852
07/24/14 04:25 PM
07/24/14 04:25 PM
dogdays Offline
dogdays  Offline
Rats, I forgot about those.
Ya just haveta love Mopar for having all those different "Detroit balance" values.
I think ford had a better idea. 28 oz-inch or 50 oz-inch or internally balanced.
R.
Re: Weight on flywheel? [Re: SLOW67] #1649853
07/25/14 08:26 PM
07/25/14 08:26 PM
ohio
prochamp Offline
prochamp  Offline
ohio
if you bought a new flywheel for your 318 specifically the weight could be for the balance of the flywheel. if you take it off you may create an imbalance.
