71 Barracuda Heater Water Valve
#164959
12/09/08 05:08 PM
12/09/08 05:08 PM
Posts: 166 Grandville, Michigan
Dustya440
I'm getting ready to install a new water valve for my 71 with a 383 2 barrel. Does anyone have pictures or infor showing the correct way to mount and install it. Thanks in advance for any help! ![](/ubbthreads/images/graemlins/smilie_help.gif)
1969 Road Runner J Code
1970 Road Runner VOA
1971 Dart Swinger
1971 Cuda Vert
1973 Duster Pro Street
2003 Z06
Re: 71 Barracuda Heater Water Valve
[Re: ebodyseast]
#164966
12/10/08 12:34 AM
12/10/08 12:34 AM
Posts: 500 NoVa
ebodyseast
NoVa
The cable in 1970 passes through the firewall on either the LH or RH side. All '71's may pass through the RH. Check ![](/ubbthreads/images/graemlins/scope.gif) the grommet under the blower motor for two holes or check the RH side of the firewall for an extra hole. The cable is the secured to the valve with these clips. The self adjusting clip is missing/not yet installed/never was one on the Challenger above. The 1970 service manual goes into detail on how the cable is best installed.
[Re: Snoopy]
#164971
12/10/08 08:03 AM
12/10/08 08:03 AM
Posts: 21,515 It's a dry heat
gtx6970
It's a dry heat
I think the hole you have circled is for the Christmas tree fastener for the dash insulation.
Snoopy, The cable on my former 70 challenger 340 the cable had an insulated rubber tube that the cable used to pass thru the insulation/firewall that replaced the plastic christmas tree
[Re: gtx6970]
#164972
12/10/08 09:56 AM
12/10/08 09:56 AM
Dustya440
Wow guys! Thanks for all the imformation. ![](/ubbthreads/images/graemlins/bow.gif) It looks like the brackets that I bought are no where near what is correct. Can anyone give me a number on how to contact Bill Rolik so I can get the right bracket? Thanks again for all the help!
1971 Dart Swinger
1971 Cuda Vert
2003 Z06
[Re: Dustya440]
#164973
12/10/08 10:43 AM
12/10/08 10:43 AM
Dustya440
Update: I found the info for Bill and will order the bracket along with some other parts today. But I still need the clips/holddown and screw that ebodyseast mentioned in one of the above post and picture. Anyone know where I can get these. I added a picture of the car so far. Thanks again for the help. ![](/ubbthreads/images/graemlins/thumbs.gif)
1971 Dart Swinger
1971 Cuda Vert
2003 Z06
[Re: Dustya440]
#164974
12/10/08 11:31 AM
12/10/08 11:31 AM
Posts: 500 NoVa
ebodyseast
NoVa
Nice conv Dustya440! She's gonna b sweet brother. ![](/ubbthreads/images/graemlins/thumbs.gif) I see it has a brake booster...so does your conv have a hole in the RH firewall and does the cable exit there? Best of luck, glad to b of assistsance. Snoopy, the firewall pic I posted above was created by someone else. Just using it here for reference purposes. Again, my '70 does not have this hole - so it can't be an insulation retainer hole. The heater cable passes through here on mosts E Bodys I've seen and owned in the past. The wire retaining clip for the blue wire may be the same clip used on the back of a Mopar alternator? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) The pan head screw used to secure them will be easy enough to find in my Mopar used screw collection...
[Re: 71rm23]
#164976
12/10/08 01:02 PM
12/10/08 01:02 PM
Posts: 500 NoVa
ebodyseast
NoVa
Another topic of interest here includes the overall length of the E Body heater cables from 1970-74. '70-71 parts catalog states there are two cables used in '70. One is 71" and the other is 74". Maybe a misprint? Anyone have or seen a 74" cable?The original cable in my '70 is 71" to help in finding out. For '71 E Body a new 71" cable is listed & with a new part number. Most NOS 71" cables I've seen are this particular one. Did the cable length or part number change again anytime between 1972-74 or did it stay the same? Keep 'em comin Dustya440! ![](/ubbthreads/images/graemlins/Santa4.gif)
[Re: ebodyseast]
#164978
12/10/08 01:48 PM
12/10/08 01:48 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
The firewall is from a non-a/c 4-speed 70 Cuda.
I think Bill is correct about the insulated rubber tube that replaces the Christmas tree fastener.
