Transmission suggestions please
#1649446
07/21/14 11:50 PM
07/21/14 11:50 PM
Posts: 34,958 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Asked a few times, seems to be hard to get agreement Street strip car .. I'd like an OD trans but // I really need to decide, soon http://www.cuda-challenger.com/cc/index.php?topic=84774.0Opinions, ideas, suggestions ? Should I put a manual in it ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Transmission suggestions please
[Re: DaytonaTurbo]
#1649449
07/22/14 02:19 AM
07/22/14 02:19 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Here are a couple things I'm against. When 1st is not low enough, when the top gear is not high enough and wide ratios. The manufacturers have figured it out. That's why a 8 spd Hemi Ram can haul, accelerate, get mileage and have a low cruising rpm. Most super luxury perf cars from Germany have 7,8 and 9 speeds. There are 11, 12 sec cars that can go 150-200mph. A Viper with 6 speeds is strong out of the gate and car go 200mph. I've done the 518 w lock up swap so I"m not just spewing here. You need alot of floor modifications and it's huge and inefficient. The ONLY reason to consider a 518, it's a Mopar trans. It's not cheap but next time, I'm going with this.
[Re: MidPenMopar]
#1649450
07/22/14 02:35 AM
07/22/14 02:35 AM
Posts: 6,570 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
It would be nice if the guy that did the thread on that swap would share the drawings for that cross member. ![](/ubbthreads/images/graemlins/thumbs.gif) Some of the other stuff not so much ![](/ubbthreads/images/graemlins/laugh2.gif) but a good write up none the less. What is this going behind? The A500 might be a better/easier fit depending on how much torque you plan to feed it. Kevin
[Re: bigdad]
#1649451
07/22/14 11:33 AM
07/22/14 11:33 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Street strip car ..
If your going to want an OD and a manual, T56 6 speed .050 OD
[Re: DAYCLONA]
#1649452
07/24/14 03:57 AM
07/24/14 03:57 AM
DaytonaTurbo
Manitoba, Canada
Good trans, just be aware that unless you cough up the money for a T56 magnum, you will spend some $$$ doing trans upgrades if you plan to throw any amount of power at it. I think the most common units are only rated to 450ft-lbs.
