Clicking noise from front wheel #1649429
07/21/14 11:06 PM
07/21/14 11:06 PM
Pennsylvania
ColorMeGreen Offline OP
Pennsylvania
Any suggestions? It's a 72 Charger with front drums and steel rally wheels. Trim rings and centers are tight. It has new ball joints, bushings, tie rods and sleeves. Just changed the wheel bearings and races on the left side where it sounds like the clicking is coming from. It only happens on a slight right turn over 20mph and increases with speed. I'm at the point where I'm watching for the wheel to fly off!
Re: Clicking noise from front wheel [Re: ColorMeGreen] #1649430
07/21/14 11:08 PM
07/21/14 11:08 PM
Alberta, Canada
300rag Offline
300rag  Offline
Alberta, Canada
Pull off the trim rings and try again. You may be surprised. Been there, done that.
Peter
'65 300 'vert 413/4spd
'18 Challenger R/T Shaker
'19 Durango R/T
Re: Clicking noise from front wheel [Re: 300rag] #1649431
07/21/14 11:12 PM
07/21/14 11:12 PM
Pennsylvania
Pennsylvania
I'll pull that side off tomorrow, I was going to swap a wheel next and try that. Thanks
Re: Clicking noise from front wheel [Re: ColorMeGreen] #1649432
07/21/14 11:25 PM
07/21/14 11:25 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Did the noise start after you replaced the bearings? I would also remove the trim rings and road test. I've also had the cotter pin hit the inside of the dust cap and make a clicking sound
Re: Clicking noise from front wheel [Re: 300rag] #1649433
07/21/14 11:32 PM
07/21/14 11:32 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Same here.
Facts are stubborn things.
Re: Clicking noise from front wheel [Re: Dcuda69] #1649434
07/21/14 11:38 PM
07/21/14 11:38 PM
Pennsylvania
Pennsylvania
I noticed small dents on the side of the dust cap and punched them out. I thought for sure that was it. Replaced the bearing tonight thinking that would solve it too but didn't.
Re: Clicking noise from front wheel [Re: ColorMeGreen] #1649435
07/23/14 10:51 PM
07/23/14 10:51 PM
Pennsylvania
Pennsylvania
Well, I pulled the trim ring off and I can't believe my ears. No clicking! Looks like the wheel weight is part of the problem. Thanks for the help!
