Koleno block with Edelbrock Victor Heads Question #1649178
07/21/14 11:39 AM
07/21/14 11:39 AM
Omaha, NE
dart69bigblock Offline OP
Omaha, NE
I have a couple of questions that hopefully someone can answer.
1. Can Edelbrock Victor heads be used with a 4.5" bore
2. Can the Victor heads be modified for rear oiling to work with a Koleno block or the block modified for stock oiling?
Thanks for any help that can be provided.
Chris
Re: Koleno block with Edelbrock Victor Heads Question [Re: dart69bigblock] #1649179
07/21/14 08:03 PM
07/21/14 08:03 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I use the stock oiling with a KP440 block and victor heads but 4.350 bore.I use a mig tip to restrict oil to the rockers in the rocker stand.
Re: Koleno block with Edelbrock Victor Heads Question [Re: Clanton] #1649180
07/22/14 01:23 AM
07/22/14 01:23 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
IT was a mopar block but the last one we did we oiled if off the back like an indy head but drilled and tapped oil line fittings on the center rocker shaft stand. Oiled the Harlands great.
Todd
