Lil Red Express Gas Tank #1649174
07/21/14 10:01 AM
07/21/14 10:01 AM
ga
ringo440 Offline OP
ringo440  Offline OP
ga
Anyone know a good repair for a crack in the plastic gas tank. or should I just replace it. If so where to find new tank.
Re: Lil Red Express Gas Tank [Re: ringo440] #1649175
07/21/14 12:09 PM
07/21/14 12:09 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
There's really no way to repair the plastic tanks on our trucks & nobody makes new tanks for our trucks. Im kinda hoping that LMC might change that option some day, but I won't hold my breath. All you can do is search the salvage yards or mopar swap meets, I'm sure someone on this website has one sitting around I think any 76-80 with the saddle tank will work other than it being a different size tank.
Re: Lil Red Express Gas Tank [Re: 98RAM1500] #1649176
07/21/14 01:01 PM
07/21/14 01:01 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Um, yes their is a way to repair plastic gas tanks. I plastic welded mine after watching this on you tube ('76 Dodge Adventurer Sport). Holds gas fine now. I do have some pics.
http://www.youtube.com/watch?v=EbtUxJJs8G0
Re: Lil Red Express Gas Tank [Re: 98RAM1500] #1649177
07/21/14 02:30 PM
07/21/14 02:30 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I weld them & have for 30 years or so now without the first failure I use a soldering iron to do it with too!
