What gauge of wire are you using with your relocation? #1648980
07/20/14 11:58 PM
07/20/14 11:58 PM
Carstairs, Alberta, Canada
dave571 Offline OP
dave571  Offline OP
Just curious, as I'm working on a dart with a pretty stout 440.
It has 2gauge, and I think it needs more. I'm want to move up to 0 gauge.
Thanks in advance.
Re: What gauge of wire are you using with your relocation? [Re: dave571] #1648981
07/21/14 12:14 AM
07/21/14 12:14 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Thanks in advance.
huh? you mean battery cable? I use 4 gauge
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: What gauge of wire are you using with your relocation? [Re: dave571] #1648982
07/21/14 12:42 AM
07/21/14 12:42 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
imho if it's a quality wire (i only use welding cable) id leave the 2ga in there. if it's properly installed it should be fine.
Re: What gauge of wire are you using with your relocation? [Re: jamesc] #1648983
07/21/14 01:44 AM
07/21/14 01:44 AM
dave571 Offline OP
dave571  Offline OP
With a new powermaster starter, the ignition disconnected, and two red top optima batteries, it doesn't want to turn over hot.
We've replaced the starter 3 times, and just upgraded the cutoff switch to a 300 amp unit.
I recommended heavier wire to the owner of the car prior to the last starter change, but he wanted to try this first.
The 2AWG wire that is in the car now, came with the Taylor wire products relocation kit.
I know they sell the kit with 1awg too, so I was curious what other guys were using.
We're running out of things to rule out.
Re: What gauge of wire are you using with your relocation? [Re: dave571] #1648984
07/21/14 01:56 AM
07/21/14 01:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure the ground is good... and as large as the
hot positive lead
Re: What gauge of wire are you using with your relocation? [Re: MR_P_BODY] #1648985
07/21/14 02:28 AM
07/21/14 02:28 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What gauge of wire are you using with your relocation? [Re: pittsburghracer] #1648986
07/21/14 02:31 AM
07/21/14 02:31 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I use 2/0 for starter power and body grounds.
Re: What gauge of wire are you using with your relocation? [Re: pittsburghracer] #1648987
07/21/14 02:37 AM
07/21/14 02:37 AM
dave571 Offline OP
dave571  Offline OP
http://www.powermastermotorsports.com/charge_wires.html
Interesting. Shows 0 or 00 depending on the draw, on that chart.
I suggested 0 to the owner, prior to seeing that chart.
Thanks for the link.
And yes Mr. P body. I agree, that the ground needs to be as big. There are several heavy grounds on this rig. We started there.
Re: What gauge of wire are you using with your relocation? [Re: dave571] #1648988
07/21/14 02:43 AM
07/21/14 02:43 AM
RobX4406 Offline
RobX4406  Offline
Another
Got to figure both ways, so the it's like 20' or 240".
Re: What gauge of wire are you using with your relocation? [Re: RobX4406] #1648989
07/21/14 11:33 AM
07/21/14 11:33 AM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
I go to the welding supply and get the biggest cable they have. That is one area I want absolutely no trouble from. Welding cable will have far less voltage drop than a battery cable will and is also more flexable for routing.
Back in the swing of things at Painless again! Great to be back!
Re: What gauge of wire are you using with your relocation? [Re: BJS racing] #1648990
07/21/14 01:48 PM
07/21/14 01:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ran the BIG welding cable for years but when I re did my interior, I had Napa make me a #2 iirc which was way smaller AND lighter and it works great. Like Mike said, the grounds are very if not MORE important the the lead wire.
Re: What gauge of wire are you using with your relocation? [Re: Thumperdart] #1648991
07/21/14 02:10 PM
07/21/14 02:10 PM
Most hot rodders that do not have a education in electrical theory don't know that all the battery current travels from the battery(all battery are the same)negative post through the sytem and returns to the battery through the positive post Hence the importance of the negative leads
Re: What gauge of wire are you using with your relocation? [Re: Cab_Burge] #1648992
07/21/14 02:29 PM
07/21/14 02:29 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Hence the EQUAL importance of the negative leads
Re: What gauge of wire are you using with your relocation? [Re: jcc] #1648993
07/25/14 01:26 AM
07/25/14 01:26 AM
dave571 Offline OP
dave571  Offline OP
Update
0 gauge both ways. Turns over like it doesn't even have plugs in it.
Thanks.
