Anyone ever spray PPG Omni? Help! #164879
12/09/08 01:18 PM
12/09/08 01:18 PM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
I bought a gallon of PPG Omni (F6 Bright Green) with the intent of spraying my trunk, engine compartment and jambs and maybe saving a couple bucks on my paint job. A paint shop will finish the job using Glasurit. I mixed it 50/50 with omni medium reducer, and the stuff sprays like green water. I figure it will take 3-4 coats to get full coverage. Is this normal or did I do something wrong? I'm certainly no painter.
Re: Anyone ever spray PPG Omni? Help! [Re: Mike H] #164880
12/09/08 01:20 PM
12/09/08 01:20 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
formula doesnt sound right..double check it
Re: Anyone ever spray PPG Omni? Help! [Re: Mike H] #164881
12/09/08 01:26 PM
12/09/08 01:26 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Omni paint is very thin and takes more coats for proper coverage. I don't care for it.
Re: Anyone ever spray PPG Omni? Help! [Re: Challenger 1] #164882
12/09/08 01:40 PM
12/09/08 01:40 PM
i had the same problem with it. I hated it. it took forever to dry also. i'd never use it again. plus it was too yellowy for sublime but that was probably the mixers fault
Re: Anyone ever spray PPG Omni? Help! [Re: Mike H] #164883
12/09/08 01:55 PM
12/09/08 01:55 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Are you using MBC (base coat?)--I've used it many times, never a problem. Sure its thin, but 2nd coat should provide complete hiding.
Re: Anyone ever spray PPG Omni? Help! [Re: Mike H] #164884
12/09/08 02:27 PM
12/09/08 02:27 PM
Ohio, USA
Dr-Dave2 Offline
Dr-Dave2  Offline
Ohio, USA
I think product sheets are online at PPG.com
Ive used OMNI several times and it worked great
https://buyat.ppg.com/refinishProductCat...30-6cdcae068cba
Re: Anyone ever spray PPG Omni? Help! [Re: Dr-Dave2] #164885
12/10/08 01:49 AM
12/10/08 01:49 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
My paint guy mixed some R4 red for me in OMNI and he doubled the solids part of the formula when he mixed it. Wow did it cover nice.
Anyway a lot depends on what color you are spraying.
Another Omni job I did with standard by the book mix, I put the first coat on pretty thin and tacky, then went back for two more wet coats, it came out great.
Re: Anyone ever spray PPG Omni? Help! [Re: Dr-Dave2] #164886
12/10/08 02:11 AM
12/10/08 02:11 AM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
Same
Chris from New Jersey
Re: Anyone ever spray PPG Omni? Help! [Re: Mike H] #164887
12/10/08 09:05 AM
12/10/08 09:05 AM
Jacksonville, Fl
426runner Offline
426runner  Offline
Jacksonville, Fl
My RR was painted with the Omni line. Looks good to me. When talking to a well known Mopar restorer about the Omni stuff, his only negative comment was that the Omni line is not as durable on a vehicle that spends all it's time in the elements/sun. For a pampered, garage kept collector car there should be no problems.
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: Anyone ever spray PPG Omni? Help! [Re: Mike H] #164888
12/10/08 09:09 AM
12/10/08 09:09 AM
Jacksonville Florida
elitecustombody Offline
one word, GARBAGE! ,the watered-down junk takes more coats, mre coats take more time, spend few buck more on better paint and save the hassle,oh,and whatever you do, do not use their clears, that stuff comes off the car in sheets in couple of months, I've seen it with my own eyes,my brother's shop had to re-do a few cars when they tried that GARBAGE OMNI line
Stefan
Re: Anyone ever spray PPG Omni? Help! [Re: elitecustombody] #164889
12/10/08 10:18 AM
12/10/08 10:18 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Stefan
As is the majority of the PPG line
Re: Anyone ever spray PPG Omni? Help! [Re: DAYCLONA] #164890
12/10/08 10:42 AM
12/10/08 10:42 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i am a PPG certified painter for more than 25 years. i really haven't had ANY problems with PPG paints.
if OMNI clear coat falls off in sheets why hasn't it on my car painted over 6 years ago.
you must have slammed the base coat on WAY to fast or waited to long before clear coating.
the problems with the base coats being to thin is because the older colors were not reformulated for base coat just converted over to base coat. when this happens they take the single stage formula and add the clear tint them add base coat binders. when they do that it has 2X as much clear tint in the formula than if it were single stage color.
perception is 90% of reality
Re: Anyone ever spray PPG Omni? Help! [Re: elitecustombody] #164891
12/10/08 10:43 AM
12/10/08 10:43 AM
Stefan
And my daily driver has Omni single stage on it, just a scuff and squirt job I did 4 years ago, car is never garaged, waxed twice and it still looks great.
I painted my daughters Honda door and hood three years ago, base clear, (Seattle Silver), match was great, car is never garaged, never waxed, still looks great.
I painted a Porsche 944 door for a freind awhile back-still looks great.
I use omni whenver I want to save 1/3 to 1/2 on the paint materials cost.
Its never dissappointed me.
Re: Anyone ever spray PPG Omni? Help! [Re: Pacnorthcuda] #164892
12/10/08 11:42 AM
12/10/08 11:42 AM
wv
Dartcuda Offline
Dartcuda  Offline
wv
Where did you get the Omni ? Its been discontinued for over a year. Its called shopline now . 50/50 is way to thin should be 10%-25% reducer . It will take more coats but for a budget job you can't beat it . I just painted the hood , bumper cover and 1 fender on my sons Corolla using shopline single stage and 3 coats only took 2/3 quart and it looks great. 1 quart only cost $30.10. Get your mixture correct then spray 1 light misty tack coat wait 10 minutes spray a medium coat 10 minutes than a heavy coat repeat if you think you need a 4th coat. That how I do the single stage but the base and clear I do the same.
Re: Anyone ever spray PPG Omni? Help! [Re: Dartcuda] #164893
12/10/08 01:42 PM
12/10/08 01:42 PM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
50/50 doesnt sound right
3 or 4 parts paint : 1 part reducer
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: Anyone ever spray PPG Omni? Help! [Re: moepwr] #164894
12/10/08 02:41 PM
12/10/08 02:41 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I dont have an answer, but my car was sprayed with omni paints. for everything it was 420 bucks. cant beat that. my dad painted it in our shed. dirt floor, threw down ply wood and draped plastic sheets. now we have concrete and started making a real paint booth. it was painted summer of 2006 and no problems thus far. did i mention this was my dad's first paint job...
Re: Anyone ever spray PPG Omni? Help! [Re: moepwr] #164895
12/10/08 03:17 PM
12/10/08 03:17 PM
The Omni MBC (base coat) is 1:1 its the single stage paints that are typically 4:1:1
Re: Anyone ever spray PPG Omni? Help! [Re: Mr T2U] #164896
12/10/08 05:28 PM
12/10/08 05:28 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
Yea, some of these posts are crazy, show me a paint job where the clear comes off "in sheets" in a few months and I will show you a breakdown in the preperation of the surface or materials involved. Not a damn thing wrong with Omni. Ive had two company cars painted with it.
Re: Anyone ever spray PPG Omni? Help! [Re: Mike H] #164897
12/10/08 06:28 PM
12/10/08 06:28 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
I never sprayed PPG Omni but I did have my Omni sparyed with PPG (PR4 Flame Red)?
Re: Anyone ever spray PPG Omni? Help! [Re: DAYCLONA] #164898
12/10/08 06:35 PM
12/10/08 06:35 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Stefan
WOW! That's really sad to hear...especially as an OE supplier for the Big 3 for so many years...no WONDER they're all on the verge of bankruptcy...
In my past experience both using products and watching others, 99% of problems stem from the craftsman, yet gets blamed on the product. Improper prep, not enough flash time, not mixing the ratios correctly, insufficient heat...you name it. Fact is, I've seen all the aforementioned problems with PPG/Omni, DuPont/Nason, Martin Senour (big through NAPA up here years ago), and NONE of these products like to be treated the same. I know of one shop that will only use PPG primers, but prefers DuPonts lineup for paint. Apparently a no-no (according to the dist), but it works fine for him.
And lets not forget the gun...if, as mentioned, the paint is somewhat thin to begin with, and the gun is putting as much paint in the air as it is on the car...well, you get the idea...
2 Demons...no, not my kids!
