Cam Card Info .... #1648753
07/20/14 03:50 PM
07/20/14 03:50 PM
Maryville tn
67coronetman Offline OP
Maryville tn
Would anyone have a copy of the actual Cam Card of the mopar 312/590 Cam i need to see all the info and what they say to set the Valve Lash at and i do have aluminum heads.
Thanks for any help.
Old car are me......
Re: Cam Card Info .... [Re: 67coronetman] #1648754
07/20/14 04:08 PM
07/20/14 04:08 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
http://victorylibrary.com/mopar/mpcam-tech-c.htm
The 528 Cam I just bought also came with a generic sheet listing the specs of all the MP cams. It seems that all MP solid cams use the same .028/.032 lash INT/EXH.
Re: Cam Card Info .... [Re: 67coronetman] #1648755
07/20/14 04:36 PM
07/20/14 04:36 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
They say to set the lash 28/32 hot with iron heads I used to go 26/30 cold and that gave 24/26 hot I like a little tighter. LSA is 106 with 104 intake centerline install better at 102 or we even ran one at 99.5 then later 101. Aluminum heads lash actually opens up .004 to .006 hot and more with Indy heads.
312 duration is 265 Duration @ .050. they never cam with a cam card as far as I know. I never got one in any Mopar Performance / Direction cam I ever got.
Re: Cam Card Info .... [Re: Dodgem] #1648756
07/20/14 04:46 PM
07/20/14 04:46 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the mp590 I installed in a 360 in April was 272 @.050 on the degree wheel..
Tony
70 AARCuda Vitamin C
Re: Cam Card Info .... [Re: 70AARcuda] #1648757
07/20/14 04:52 PM
07/20/14 04:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You sure it's not a .620 320 duration? LOL they do mark their cams well or at all! :-)
Re: Cam Card Info .... [Re: Dodgem] #1648758
07/20/14 04:53 PM
07/20/14 04:53 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
But i can read part numbers on the box...
i am sure...Do a search over in the race section...others have measured it at 272 also
Fast68Plymouth posted the 0.590" cam years ago:
.020" 303.5º
.050" 270.5º
.100" 235.0º
.200" 177.0º
Re: Cam Card Info .... [Re: 70AARcuda] #1648759
07/20/14 07:32 PM
07/20/14 07:32 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Could be I degreed a couple but never felt the need to check the total duration @ .050. Course if it was on one of my gear drives you have to degree by @.50 then check other ways.
Re: Cam Card Info .... [Re: Dodgem] #1648760
07/20/14 09:30 PM
07/20/14 09:30 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I always took the Victory Library number at 265 as correct. Then several people in the racing section commented it was 272...so I checked the new one I put in that 360 back in April..and I got 271...
Mopar Muscle Magazine article last year had it at 271 also...which I thought was wrong...but nope that was correct..Actually that cam is now going to come out of that 360...lol
Tony
Re: Cam Card Info .... [Re: 70AARcuda] #1648761
07/20/14 09:43 PM
07/20/14 09:43 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Yes the 590 is 271 as I wrote , the 620 is 283. The 557 is 257.
Mopar finally corrected the chart a couple years ago.
Keith
Re: Cam Card Info .... [Re: Kern Dog] #1648762
07/20/14 09:50 PM
07/20/14 09:50 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
On that MP 590 cam and some others the published info is incorrect. They even put Notations after the specs stating that that the catalog info must of been incorrect.
The real duration of that cam is 271/272 depending on whos measuring. Its recommended lash, 28/32 Some tighten that up. Its recommended ICL is 104* 2* advanced. But most run it at a little more advanced then that. The range 99*ICL to 104*ICL
Ive got mine in at 101* ICL
Intake open 35* BTDC Intake close 56* ABDC
If you want it in @ the 104* ICL, then
Intake open 32* BTDC Intake closes 59* ABDC
Also that cam has a 106 LSA
Re: Cam Card Info .... [Re: 67coronetman] #1648763
07/21/14 12:41 PM
07/21/14 12:41 PM
Maryville tn
Maryville tn
Thnaks for all the info it gave me a good heads up...
