How to make 1200-1300 streetable HP?
#1648557
07/20/14 12:01 PM
07/20/14 12:01 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I have 3 long blocks and I would like to change 1 to a turbo or Procharger. First I have 12:1 Indy-1 500" 4.15 stroke eagle rotating assy with World Block. Second I have a 583 B1MC world block with 4.5 Calies Crank and Alum rods 14:1, and third I have a 540 -1 12:1 world block with 4.50 stroke 440 source rotating assy. Which one would be the best to change and make 1200 street able HP???
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: How to make 1200-1300 streetable HP?
[Re: 65 Hemi]
#1648558
07/20/14 12:28 PM
07/20/14 12:28 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I would go with the B1Mc motor with lower compression pistons. It is easier to put a mild cam in it and add a blower to get the 1200 hp over the others. Cubes rule, blown or not. Heads likewise. The more power you want to make, the better they need to be. I am partial to screw type blowers. Whipple has sizes that will accommodate what you want, and not break a sweat doing it. If you build an 800 hp pump gas motor, then put 7.5 psi boost to it, with an intercooler it will produce about an additional 60 percent more hp. That would get you what you want with insane off idle torque to boot.
[Re: 65 Hemi]
#1648560
07/20/14 12:36 PM
07/20/14 12:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Myself, I would do the 500" and hang 1 OR 2 turbos on it for good street manners.. you could dial in what pressure you want... low compression and if needed you can run cheap fuel with water/alky injection when in boost
[Re: 65 Hemi]
#1648561
07/20/14 12:44 PM
07/20/14 12:44 PM
gregsdart
If you like the look of turbos, those would be a great option on any of the motors you have. There is also the option of a procharger. those don't build the low speed torque of a twin screw or turbo, but make good power up top.
[Re: MR_P_BODY]
#1648562
07/20/14 12:45 PM
07/20/14 12:45 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I would go the Indy route as far as engine wise,why because they make and sell all the parts needed for which ever Forced Induction system you chose to use.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: 65 Hemi]
#1648565
07/20/14 01:51 PM
07/20/14 01:51 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
It will be hard to ONLY make 1300hp with any of those combos. I have a 500" -1 motor in my turbo car. And a Procharger on my SRT challenger. Both are diffrent animals. It's hard to choose what type is better. If you have the $$ and want it running soon then the Procharger is the way to go. It reuses your headers, and comes as a bolt on kit. If you want to save a little $$ (not much) and can fab up your hot and cold plumbing, and don't mind all the little do dads that go along with a turbo. Then figure out the learning curve of what changes in the tune (everything) then a turbo is pretty neet. I think if your going to stay carbarated then I would stick with a Procharger. And if your going to use a good stand alone EFI system like Fast or Holley then turbos start to shine. As for what combo on the street I would go the 4.15 crank combo. Hooking the 4.5 crank could be difficult.
[Re: FastmOp]
#1648570
07/20/14 03:06 PM
07/20/14 03:06 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
The 540 with twin 91's and you will see Jesus for sure.
Mopar to the bone!!!
[Re: 72Swinger]
#1648571
07/20/14 04:34 PM
07/20/14 04:34 PM
Posts: 12,396 Taxes & Virus's R-US, NY
Dragula
Life begins at 20lbs of boost... Me, simpilest way to get your project off the ground is too keep it simple. A procharger will do that. If you go to a crank driven unit, you can run a stock water pump and keep most of you normal brackets and such... Now if 1300hp is your limit, a 470 with an F1R pushed pretty hard will exceed that, meaning race gas or water injection. A 470 with an F2 will do that easy on pump gas...So a 4.15 crank and the best pistons & rings you can get. You start going above 520 cubes and you need a big air pump, and hp numbers get real big, but so do the expenses. A 572 can make +2000hp on pump gas....So cubes are really not needed. A good block heads, rods and pistons are... Now I have researched this a bit, and New Era Racecraft I liked the best with a gear drive. You don't need a lot of cubes at 1300hp even on pump gas, but other custom things add up. So if a crank drive will fit with a split radiator set-up, or even a conventional side mount, they are easy to get going. Mopars like boost! Boosted engines require better tech than some shops can provide, but read up on them. A well built engine will last... http://www.neweraracecraft.com/engine-component-kits.html(NER piston and ring packs) Stg 1P Steve's development of piston and dish / dome profiles continues here at NER. As can be seen by the pictures on this site we use a multitude of crown designs, Flat tops, inverted domes, spherical dish, conical dish, button dish and a round dish. Different engines respond differently to the quench area we give it, the most noted is the BBCHRY's. As with most all of our items we sell, it comes from the school of hard knocks, there was a problem, we work to find the solution, we test it, then we sell it. The other thing you will see in our pistons is they are hard anodized. This is the same procedure done to the Nitro pistons, it makes the pistons very tuff and it is NOT a coating like ceramic or Teflon skirts. Minor misses in tune up that would have lifted a ring land are totally eliminated, skirts are less appt to collapse and wont scuff, unless your tune up is so far out in right field you can't be seen. Third thing is the ring pack. We sell all our pistons with Total Seal steel tops, Napier seconds and varying oil rings, depending on the application we may use a Dyke ring, 1/16 std style ring, .043" in the tops. Radial wall thickness may vary too but in general we are looking for a bullet proof ring pack so std D wall will apply in most cases. 4th we only use Nickel carbon steel alloy Pins in applications above 1200HP and below we use a high carbon Pin. No std cheap Pins that come with shelf pistons. If you want the right pistons, the right crown design, and the right ring pack, you need NER's. NER piston ring packs are $1,450.00 for most applications, and are made for us by J.E. and Diamond.
[Re: Dragula]
#1648572
07/20/14 05:14 PM
07/20/14 05:14 PM
65 Hemi
San Diego CA
Thank you for your input and help. I have been leaning towards my 583 B1MC motor and changing pistons and cam and adding a F2 gear drive or side slinger with no inter cooler.
Doug
[Re: 65 Hemi]
#1648573
07/20/14 11:16 PM
07/20/14 11:16 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I build a lot of 3600lb 8 second blow thru street cars. Pump gas on the street c-16 at the track. You can't go wrong with a blow thru f-2. Don't put to much stroke in it, its not a turbo.
BB, TT5,Procharged 3300lb Street Car 4.79/154
