engine guy question about 383 #1648510
07/20/14 10:43 AM
07/20/14 10:43 AM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
checked the compression on my #s 69 roadrunner. compression #s warm were 148 to 159.Is this in tolerance? The motor is stock never out of the car.The stock heat riser is still on the car.Oil preessure is fine doesnt smoke runs and drives like it should.The only problem is when you rev the motor up the rpms are slow to come back down . I am getting ready to pull motor to do engine bay and would like to address any problems at that time i do not want to hurt #s motor any help ? thanks
Re: engine guy question about 383 [Re: 3wracing] #1648511
07/20/14 10:52 AM
07/20/14 10:52 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Compression is fine.
The problem is likely not in the motor.
Give more detail on exactly what it is doing
Re: engine guy question about 383 [Re: 3wracing] #1648512
07/20/14 10:58 AM
07/20/14 10:58 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Those numbers are normal. Back then, the engines weren't making the compression that they were rated at. My original 383 had the same numbers you are getting.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: engine guy question about 383 [Re: 68LAR] #1648513
07/20/14 02:56 PM
07/20/14 02:56 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
when you rev the motor up to say 2 grand it seems it takes a longer than normal for the rpms to settle back down to normal. Or when driving it say you shift to second the rpms stay up between shifts. I have a good return spring the carb plates are going closed . Not that it matters but the carb is a 68 -383 4spd carb that the original owner says was on it since new . . vacume is around 10" with the timing around tdc which i think is somewhat low .
Re: engine guy question about 383 [Re: 3wracing] #1648514
07/20/14 03:23 PM
07/20/14 03:23 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
If it's a completely stock 383, 10" is too low. You should be around 12" or a little higher. If the idle doesn't settle after higher rpms, you may have a vacuum leak somewhere or the carb throttle blades are hanging up. Next time you try it, try taping side to side with a very small hammer, on the carb throttle shaft(primary side),just to see if the idle drops back to normal. If it does then you know it's the carb, if it doesn't, then you know it's a vacuum leak or maybe timing. With 10", I'm leaning toward a vacuum leak, or retarded timing. 0* @TDC, with a stick car is normal with the vacuum line off of the distributor.
Re: engine guy question about 383 [Re: 3wracing] #1648515
07/20/14 05:34 PM
07/20/14 05:34 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Vacuum will be low at TDC timing as it should be about 10 degrees Before TDC, advance the timing some and the vacuum will come up to where it should be.....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: engine guy question about 383 [Re: HemiRick] #1648516
07/20/14 06:11 PM
07/20/14 06:11 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
if its a completely original untouched 4 speed car and carb, you should have a dashpot that looks like the one on my 68, you set that dashpot to touch the lever at 2K if i remember correctly from the FSM and it will drop to idle slower than cars without the dashpot. It should drop about 1 to 2 seconds slower than a normal carb. if you dont have the dashpot then maybe timing or throttle blades open to far???
Re: engine guy question about 383 [Re: ademon] #1648517
07/20/14 06:12 PM
07/20/14 06:12 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
one more pic
Re: engine guy question about 383 [Re: ademon] #1648518
07/20/14 06:42 PM
07/20/14 06:42 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I forgot about the dashpot.
Back in 68 & 69 stick car timing was TDC. Auto's were 2* BTC for 383's.
Re: engine guy question about 383 [Re: 68LAR] #1648519
07/20/14 08:09 PM
07/20/14 08:09 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
this is the carb on my 69. Sorry its dark its an n96 car also
Re: engine guy question about 383 [Re: 3wracing] #1648520
07/20/14 08:22 PM
07/20/14 08:22 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
With the motor off have someone hold the Pedal to the floor, you should see the dashpot plunger extend out, then you should be able with your finger to depress it in and it should have some resistance once in let go and it should extend out smoothly. They do go bad often
Re: engine guy question about 383 [Re: ademon] #1648521
07/20/14 08:37 PM
07/20/14 08:37 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
Check the secondary throttle plates and make sure they're not sticking as well.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: engine guy question about 383 [Re: johnedod] #1648522
07/20/14 11:22 PM
07/20/14 11:22 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I could be wrong but from what I remember dashpots were mostly only on auto trans cars. They were used to help catch the idle on auto cars so if you let off the gas real quick in gear it would bring the idle down slow so it would not stall. But I only remember them on auto cars as stick cars did not really need them. But it looks like your carb in the picture has the dashpot on it. Ron
Re: engine guy question about 383 [Re: 383man] #1648523
07/21/14 01:55 PM
07/21/14 01:55 PM
dogdays Offline
dogdays  Offline
I wasn't doing Mopars back then, but on GM cars the slow closers on the throttle were mostly on stick cars. The reason being that during emissions testing, dropping the throttle closed quickly increased the unburned HC and CO. Stick cars had many more times of throttle-off, throttle-on because of shifting.
R.
Re: engine guy question about 383 [Re: dogdays] #1648524
07/21/14 08:17 PM
07/21/14 08:17 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
That's what I hear also, plus smoother shifting.
Re: engine guy question about 383 [Re: ademon] #1648525
07/21/14 08:35 PM
07/21/14 08:35 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
69 would have a dashpot and it's a 4speed thing.
Re: engine guy question about 383 [Re: 3wracing] #1648526
07/21/14 08:58 PM
07/21/14 08:58 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Carter 4615S is the stock carb for '69 383 manuals and will have the dashpot. It does slow the return to idle from 2000+RPM. Keeps the vacuum advance raised while dropping throttle while speed shifting, reducing emissions. 4426S for '68 carb and it too will have the dashpot.
http://www.tocmp.com/manuals/Carbs/Carter/Chrysler/1965-1979/pdf/Chrysler121-173.pdf
Scroll down to Form 5526C for '68 AVS parts list
and Form 5534A for '69 parts list. There is a difference in primary rods and secondary jets.
Re: engine guy question about 383 [Re: Pynzo] #1648527
07/21/14 09:53 PM
07/21/14 09:53 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
You say this motor has never been out of the car. You MUST check if you have the stock single roller aluminum w/ nylon teeth cam gear as it will cause your low vacuum issue as well as cylinder pressure issues due to retarded cam timing. If it's still in there get rid of it. Check this way: pull the distributor cap and watch the rotor as you grab the fan belt on both sides of crank pulley. Pull the belt so's crank spins in reverse direction of normal rotation. If you spin the crank more than 5 degrees without the distributor rotor moving- you've found your problem.
Re: engine guy question about 383 [Re: Pynzo] #1648528
07/22/14 07:38 PM
07/22/14 07:38 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
yes thier is slop the way you describe in the timing chain. Yes it made me nervous . With the timing light it doesnt jump around the way some do . Thanks for all the help guys!
Re: engine guy question about 383 [Re: 3wracing] #1648529
07/22/14 07:49 PM
07/22/14 07:49 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Put in a decent double roller before you pull the engine and redo your tests. It can be done with gasket kit for under $100.
