Page 1 of 3 1 2 3
Building a d150 street strip. #1648412
07/20/14 12:27 AM
07/20/14 12:27 AM
junction city oregon
V
viperblue72 Offline OP
V
My plans are to build this into a economical street strip ride with a mild 440 with a 75mm turbo.
My ?'s are, can I get fiberglass bumpers roll pan for this? Or use car bumpers? I plan to get a hood too. Any other ways to lighten it up without butchering?
What are you truck guys runnning for rear suspension and tire sizes without moving the frame rails? Pictures would be great.
Initially this truck is just going to get a low mile motorhome 440 with 440source heads, a single s475 75mm turbo with a turbo rv 440 manifold. But yes it will be blow through.
Re: Building a d150 street strip. [Re: viperblue72] #1648413
07/20/14 01:18 AM
07/20/14 01:18 AM
Mountain City, TN
JesseR Offline
JesseR  Offline
Mountain City, TN
Us body source make hoods and a complete glass front end. I got my cowl hood from them and I believe I got the roll pan from summit. I"ve had up to a 33x19.5 sportsman pro on my truck with factory frame rails. I use a stock width a body axle with ladders and coil overs, if I had it to do over I would have left the springs and just went with cal tracks. You can fit plenty of tire with the stock springs in place. I run a 29.5x10.5 on a 12" wheel with tons of room now.
82' dodge pickup with a 499 low deck
Re: Building a d150 street strip. [Re: JesseR] #1648414
07/20/14 01:24 AM
07/20/14 01:24 AM
V
V
Jesse,
Very nice truck. Mind telling me how much your truck weighs and what your running for engine?
Re: Building a d150 street strip. [Re: viperblue72] #1648415
07/20/14 01:38 AM
07/20/14 01:38 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Very nice.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Building a d150 street strip. [Re: pittsburghracer] #1648416
07/20/14 01:43 AM
07/20/14 01:43 AM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^Thax you^^^
nice truck I use to own a 73 d-100 never should have sold it, those trucks has lots of room in them for a turbo build.
Re: Building a d150 street strip. [Re: JesseR] #1648417
07/20/14 01:44 AM
07/20/14 01:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I built a 87 D150 with ladder bars and if I knew then
what I know now I would have put a 4-link in it.. your
gonna have a pretty lame weight balance on a pick up
and the 4-link will help cover it up.. my truck had
a decent 60' with a 1.38 but a 4-link could have got
it better... you have to make up for the weight balance
Re: Building a d150 street strip. [Re: pittsburghracer] #1648418
07/20/14 01:51 AM
07/20/14 01:51 AM
Mountain City, TN
JesseR Offline
JesseR  Offline
Mountain City, TN
With a iron headed small block and a 904, it wieghed 3400lb with me and I'm 190ish. I have not wieghed it with the 5.7 hemi that's in it now. I believe the new hemi is lighter though. I raced the truck back when I ran the small block and I can tell you the best money I spent on the suspension was a set of moroso front coil springs. We we're going 1.35 to 1.37 sixty foot times back then. Truck is just a cruiser now with the hemi, thanks for the compliments guys.
Re: Building a d150 street strip. [Re: MR_P_BODY] #1648419
07/20/14 01:52 AM
07/20/14 01:52 AM
V
V
That's what I was thinking mr P. I'm not sure how well it would do with cal tracs, but the leaf spring would keep the truck more useful if I want to haul something.
I have a rv turbo manifold that I am going to use for now, although ill have to put a t6 adapter on it. I will also just use a 8 3/4 with 3.55's for now.
Re: Building a d150 street strip. [Re: JesseR] #1648420
07/20/14 01:56 AM
07/20/14 01:56 AM
V
V
Your truck is very inspiring.
Re: Building a d150 street strip. [Re: viperblue72] #1648421
07/20/14 02:05 AM
07/20/14 02:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
ANY TIME you want a multi purpose ride you sacrifice
on both ends(you cant have the best of both worlds)..
I tried and it was fair (at best) of either... but
I did play a bit more to the drag racing side.. and
yes I still hauled some junk in the bed
Re: Building a d150 street strip. [Re: MR_P_BODY] #1648422
07/20/14 06:41 PM
07/20/14 06:41 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
My D50 is very nose heavy and I am using stock leaf springs and caltrack bars. I have had a 1.33 60 t. so far.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Building a d150 street strip. [Re: D-50] #1648423
07/21/14 01:04 AM
07/21/14 01:04 AM
V
V
So you guys are saying that with cal tracs and a big slick with the stock leaves I should be able to make it hook decent?
Re: Building a d150 street strip. [Re: viperblue72] #1648424
07/21/14 01:34 AM
07/21/14 01:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It might hook.. but with a 4-link you get plenty of
adjustment to make it hook... you arent moving the IC
length on springs but you can with the 4-link.. by
the time you buy the caltrac you can build a 4-link
but you would have to build it
Re: Building a d150 street strip. [Re: MR_P_BODY] #1648425
07/21/14 08:15 PM
07/21/14 08:15 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have a 92 D150 that I bracket race on occasion, it only runs low 15s but hooks well in the low 2.0s, I only have the front of the stock springs clamped, a cheap set of traction bars, a pair of B-Body Rancho shocks and the rear is lowered with longer shackles. I was considering tubbing it to the frame rail for looks but , it works well with the M/T Drag radials. If I ever build the 360 magnum I have to replace the stock 5.2 I might need more. Yes Summit makes a roll pan I bought one last year and put it on , it fits nice but needed a little modification to fit. AAR / Stinger also makes a nice R/T hood for Dodge trucks, I am going to purchase one over the winter. Their quality is very good and I believe its around $600. I have one of their trunk lids on my Dart and it is very nice. U.S. Body Source does offer more glass parts also.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Building a d150 street strip. [Re: MR_P_BODY] #1648426
07/21/14 08:50 PM
07/21/14 08:50 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
My caltrack bars are also home made. The only thing store bought is the rod ends for the bars. And I am running 315/60 MT Drag Radials.
Re: Building a d150 street strip. [Re: D-50] #1648427
07/21/14 09:21 PM
07/21/14 09:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
And your at 2900# vs a D150... if I want it to hook
under all conditions I would just go with a 4-link...
is there anything better.. you tell me
Re: Building a d150 street strip. [Re: MR_P_BODY] #1648428
07/21/14 09:36 PM
07/21/14 09:36 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
He said it was going to be a mild setup and he can get bigger tires than I am running. I do not see why he would have any traction problems.
Re: Building a d150 street strip. [Re: D-50] #1648429
07/22/14 12:09 PM
07/22/14 12:09 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
I flipped the rear on top the leaf springs on my truck and i have caltracs on it with rancho shocks. hooks very well and been well into the 10's on low boost. i run 30x9 hoosier radial slicks or 295/65 drag radials
i can tell you this you are shorting yourself on that s475 (75mm) turbo on a 440. mine is a .30 over 360 and could benefit from a 80-88mm turbo. That 75 mm is tiny on a 440
i have a AAR brand Fiberglass hood on my truck, and rear fenders on the bed are fiberglass. i have a mild steel 6 point bar in the truck with a small block turbo'd and the heat and a/c stuff removed. with me in it (200lbs) it weighs 3750. you should also look into 2.94-3.23 gears for it too. Turbos love the load.
please listen to people who have actual running and fast turbo stuff and not magazine mechanics
look up CW25 on here and turbomustangs.com. He had a 1980 big block turbo'd truck to help ya with turbo routing for a big block. his was a stroked 400 i think though
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: Building a d150 street strip. [Re: dodge turbo] #1648430
07/22/14 07:49 PM
07/22/14 07:49 PM
V
V
Thank you guys for all of the advice.
Re: Building a d150 street strip. [Re: viperblue72] #1648431
07/22/14 11:12 PM
07/22/14 11:12 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I tried staying with my stock leafsprings but they kept trying to kill me. I contacted Calverts to ask if they could make me up a set that would work. They told me they couldn't help me so I built a 4-link and never looked back.Dave
Page 1 of 3 1 2 3
