Cruise servo applications? #1648186
07/19/14 12:49 PM
07/19/14 12:49 PM
Puttin' on the foil in Charles...
not_a_charger Offline OP
Mr. Big Shot Moparts Moderator
Can anyone tell me for which years/models this cruise servo would be correct for?
Earning every penny of that moderator paycheck.
DBAP
Re: Cruise servo applications? [Re: not_a_charger] #1648187
07/19/14 01:44 PM
07/19/14 01:44 PM
West Central Wisconsin
DeMopuar Offline
DeMopuar  Offline
I'm not exactly sure what model year this servo was started for each different Mopar model, but for Cudas and Challengers these servos were used from 1970 on up into the late 70's or early 80s for everything else. I know this servo was used in everything Mopar made in the 70's from cars to trucks to vans. The thing you really have to watch for is the cruise lever. This type of cruise servo will only work with the four wire cruise lever, not the earlier 3 wire. Without getting too carried away about cruise levers, there are two basic types that look different on the business end, but they operate exactly the same. The main takeaway here is that they need to have four wires coming out of the cruise lever. I believe the four wire colors are white, yellow, blue, and black. Just as a heads up for these cruise levers, you do need to be careful about the switch side as they are not all the same. Some cruise lever connectors to the switch have just a hole, some a small threaded hole with the common Mopar stops built into the end, others have a straight male threads on the end. What I'm trying to say is that there are many different ends out there to hook into the turn signal switch, you really have to be careful and know which one your looking for. Then there are ones that are longer and have different angles -- but that's a whole different discussion.
Good luck!!!
Mark
Re: Cruise servo applications? [Re: DeMopuar] #1648188
07/19/14 03:32 PM
07/19/14 03:32 PM
Thanks for the info.
So this one is good for anything 70-up? It was in my 73 Coronet, with a 77 Cordoba tilt/cruise column, and it worked great.
DBAP
Re: Cruise servo applications? [Re: not_a_charger] #1648189
07/19/14 07:01 PM
07/19/14 07:01 PM
DeMopuar Offline
DeMopuar  Offline
Yes, that would be pretty fair to say. More accurate to say that it would fit any system with a four wire cruise lever -- then there would be no confusion for the earlier cruise lever with the 3 wire setup.
Re: Cruise servo applications? [Re: DeMopuar] #1648190
07/20/14 11:02 AM
07/20/14 11:02 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
3 wire was for the late 60's cars
pic
