Trying to get it to blow more air. Can the motor handle 12 volts. What I want to do is put a relay to bring the fan on hi speed. But I do not want to burn the motor up can it handle 12 volts straight from the battery. What size fuse should I put in it to protect the motor? Any help would be greatly appreciated.
