69 charger factory disc car can put on one pce rotor #1647852
07/18/14 12:08 PM
07/18/14 12:08 PM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
my buddy bought a 69 charger factory dic brake car , dual piston caliper's . can he put 1 peace rotors and single piston calipers i have the caliper brackets for the 11/34 rotors !! I have never had a factory disc car !!
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: 69 charger factory disc car can put on one pce rotor [Re: sparcy] #1647853
07/18/14 01:58 PM
07/18/14 01:58 PM
AndyF Offline
AndyF  Offline
He needs to pull the entire knuckle assembly and swap on some E-body or late model A-body brakes. Late model B-body and FMJ brakes will also work. All of this has been covered in numerous magazine articles and books over the years.
Re: 69 charger factory disc car can put on one pce rotor [Re: AndyF] #1647854
07/18/14 07:15 PM
07/18/14 07:15 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
You can get rebuild original calipers and brake pads from rock auto, or calipersonline.com. I think the rotors are available but expensive.
Re: 69 charger factory disc car can put on one pce rotor [Re: ademon] #1647855
07/20/14 11:53 AM
07/20/14 11:53 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
calipers are also $$$
As Andy said he has to swap over the spindles.
Re: 69 charger factory disc car can put on one pce rotor [Re: JohnRR] #1647856
07/20/14 11:56 AM
07/20/14 11:56 AM
BDW Offline
BDW  Offline
Re: 69 charger factory disc car can put on one pce rotor [Re: AndyF] #1647857
07/20/14 01:06 PM
07/20/14 01:06 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
would disc spindles from a '74 charger work?
..are they the same as the later FJM and diplomat style spindle?
Re: 69 charger factory disc car can put on one pce rotor [Re: can.al] #1647858
07/21/14 10:12 AM
07/21/14 10:12 AM
JohnRR Offline
JohnRR  Offline
Yes
