Aluminum-epoxy radiator repair.i
#1647606
07/17/14 07:49 PM
07/17/14 07:49 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
My rad has developed a small leak where the tubes enter the tank. The rad is an older griffin and has white epoxy sealing the tubes. Local rad shop says no way to repair.
Any ideas on how 2 repair?
I may try pooling more epoxy on it, if i can get it 2 flow.
Does anybody repair this type of rad?
Thanks in advance for any help.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Aluminum-epoxy radiator repair.i
[Re: maximus]
#1647608
07/18/14 02:49 PM
07/18/14 02:49 PM
dogdays
[Re: can.al]
#1647610
07/18/14 06:39 PM
07/18/14 06:39 PM
Von
NE Oklahoma
Griffin rads are welded and then coated in epoxy ...just weld the hole
The rad shop said it is not possible due to the epoxy.
