P0441 on a 2003 Neon?
#1647086
07/15/14 11:11 PM
07/15/14 11:11 PM
Posts: 641 Monroe NC
Luvcars69
Monroe NC
I have reset the computer a few times & keep getting this code. I know there is a purge valve under the brake booster & one in the back by the right rear wheel. How do I check these out to figure out which is bad?
Thanks in advance for any help! Tom
Making cars faster one at a time!
19 Challenger Scat Pack white 16 Ram Sport SB Regular cab black 14 Charger Pursuit silver 78 Magnum 400 gray 69 SuperBee 512 Passion 4-speed 4:10
Re: P0441 on a 2003 Neon?
[Re: rallye73]
#1647090
07/16/14 01:27 AM
07/16/14 01:27 AM
Luvcars69
Monroe NC
I did go over them from front to back & they look ok. Car is one owner & only 45,000 on it always garage kept. All I've ever done is change oil, & trans fluid & a trans solenoid. Is there a way to bench test the purge valve. My scan tool will not fire the solenoid.
[Re: Luvcars69]
#1647092
07/16/14 02:38 AM
07/16/14 02:38 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
It means that when the PCM comands the purge valve to open to purge the fuel vapors from the charcoal canister and check the system it should see a change in 02 and short term addaptive memory and it does not. The purge valve is connected to intake vacum and when the PCM comands it to open it should purge the fumes from the charcoal canister. So it could be the purge solenoid is stuck or one of the hoses from the intake to the canister is cracked or broke or even the PCM itself. But usually if its a PCM or the purge valve solenoid winding or and electrical problem it will usually set the purge solenoid code. If you have a tech you trust take to him and let him test the system with the scanner as he can comand the purge solenoid to work and test the system. That is not a test for evap leaks it is a code for testing the evap purge air flow thru the canister and purge valve into the intake as a bad gas cap wont cause that code. Ron
