P0441 on a 2003 Neon? #1647086
07/15/14 11:11 PM
07/15/14 11:11 PM
Monroe NC
Luvcars69 Offline OP
Monroe NC
I have reset the computer a few times & keep getting this code. I know there is a purge valve under the brake booster & one in the back by the right rear wheel. How do I check these out to figure out which is bad?
Thanks in advance for any help!
Tom
Making cars faster one at a time!
19 Challenger Scat Pack white
16 Ram Sport SB Regular cab black
14 Charger Pursuit silver
78 Magnum 400 gray
69 SuperBee 512 Passion 4-speed 4:10
Re: P0441 on a 2003 Neon? [Re: Luvcars69] #1647087
07/16/14 12:24 AM
07/16/14 12:24 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
My truck has this code it might be the week rubber vacuum Lines from the tank to the valve
Re: P0441 on a 2003 Neon? [Re: Luvcars69] #1647088
07/16/14 12:32 AM
07/16/14 12:32 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
The 1 in back is most likely the vent valve. The 1 in front is the purge valve. As stated I would check all the hoses from the front to the back. A good scan tool will allow you to activate the solenoids to make sure they open and close.
Re: P0441 on a 2003 Neon? [Re: ademon] #1647089
07/16/14 12:34 AM
07/16/14 12:34 AM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
Check the hoses back by the tank. The evap hoses on my 03 SRT-4 are starting to split and crack on the ends where they hook to the canister. No codes on mine yet.
Re: P0441 on a 2003 Neon? [Re: rallye73] #1647090
07/16/14 01:27 AM
07/16/14 01:27 AM
Monroe NC
Monroe NC
I did go over them from front to back & they look ok. Car is one owner & only 45,000 on it always garage kept. All I've ever done is change oil, & trans fluid & a trans solenoid. Is there a way to bench test the purge valve. My scan tool will not fire the solenoid.
78 Magnum 400 gray
Re: P0441 on a 2003 Neon? [Re: Luvcars69] #1647091
07/16/14 02:33 AM
07/16/14 02:33 AM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I battled this same problem on my Ram for 5 months. I had a small crack on my fuel pump. My fuel pump was an in tank type. Don't know about the Neon. The best thing to do is to get a smoke test. Also check your gas cap.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: P0441 on a 2003 Neon? [Re: Luvcars69] #1647092
07/16/14 02:38 AM
07/16/14 02:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
It means that when the PCM comands the purge valve to open to purge the fuel vapors from the charcoal canister and check the system it should see a change in 02 and short term addaptive memory and it does not. The purge valve is connected to intake vacum and when the PCM comands it to open it should purge the fumes from the charcoal canister. So it could be the purge solenoid is stuck or one of the hoses from the intake to the canister is cracked or broke or even the PCM itself. But usually if its a PCM or the purge valve solenoid winding or and electrical problem it will usually set the purge solenoid code. If you have a tech you trust take to him and let him test the system with the scanner as he can comand the purge solenoid to work and test the system. That is not a test for evap leaks it is a code for testing the evap purge air flow thru the canister and purge valve into the intake as a bad gas cap wont cause that code. Ron
