Re: ATTENTION DODGE DEMON OWNERS - I NEED YOUR HELP PLEASE!
[Re: jayyohe]
#1646843
07/15/14 12:18 PM
07/15/14 12:18 PM
Posts: 2,763 Myrtle Beach, SC formerly the ...
340wedge
There is no window trim on the interior. A rubber window gasket is used the same type as the windshield. Then there is the sail panels in the 1971 model which is part of the headliner.
1971 Sassy Grass Green Duster 340 2006 Charger Daytona GoMango
[Re: buildanother]
#1646846
07/15/14 01:07 PM
07/15/14 01:07 PM
Posts: 304 Export, PA
jayyohe
Export, PA
I'm fairly sure that's the big rubber window gasket, just looks blue in his photo.
Thanks - definitely looks like a blue plastic trim piece of some type to me. What else would hold the headliner up if there's no trim piece? Would the headliner have to be installed before the window gasket/window? Sorry to doubt you but I'm still confused.
[Re: jayyohe]
#1646847
07/15/14 01:15 PM
07/15/14 01:15 PM
340wedge
It looks blue in the pic but I assure you it's black. The rubber weatherstrip was black regardless of interior color and the window sits in this rubber gasket. It one piece and is the same piece of rubber on the outside of the window with the stainless trim.
[Re: 340wedge]
#1646848
07/15/14 01:39 PM
07/15/14 01:39 PM
jayyohe
Export, PA
Thanks for clarifying. The more I think back to when I stripped the headliner out, I think I do recall it being tucked behind the rear window gasket like was mentioned. It kept ripping off right at the gasket because it was so brittle. Thanks guys, you're the best.
