Re: 440 Tune Up
[Re: magic1]
#1646654
07/15/14 12:31 AM
07/15/14 12:31 AM
RapidRobert
Dial in the dist adv curve in order: initial/total/springs/vac adv. brown cap with brass inserts (see Joesixpack a member here). Firecore plug wires get regular rave reviews. Check rotor phasing. NAPA Echlin "MO3000" rotor with a .060" longer blade $8 & change out the door. Experiment with gaps from .030 to .045. NGK or autolite overseas now & the quality ain't the same as it was. 180 or 185 stat. Is that just a MSD dist or is it the regular MSD multispark system. What coil. EDIT If that is an OE AVS (& I'm assuming that it is) then it is without a doubt LEAN & I would convert to Eddy 2 step rods/short pri jets. Get a performer strip kit with rods/jets close to what you have in there and I'd go maybe 3 thou thinner (richer) on the cruise step for a start. From a prior thread: the '70 AVS has a .101 pri jet and a .066/.058 rod and no mention of the "intermediate" dia as (OE) AVS's are 3 step rods with the taller (pri) jets. Mike yours & go from there & can likely google the part number for the diameters if you ain't got no mike. Holler how thing turn out.
Re: 440 Tune Up
[Re: RapidRobert]
#1646655
07/15/14 09:15 AM
07/15/14 09:15 AM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Sounds like a very cool car. The Firecore50 Wires will fit out of the box, perfectly. All numbered and ready to go. Any pics of your car and engine? Sounds killer.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 440 Tune Up
[Re: sunroofgtx]
#1646656
07/15/14 12:49 PM
07/15/14 12:49 PM
dogdays
Hah! NGK plugs have always been made overseas, same as Nippondensos. As one of those companies made the Accel U-groove plugs, them too.
Plug gaps - the larger the gap, the larger the flame "kernel" that starts everything off. There's a reason GM went to huge gaps in the early HEI days. I have taken a set of overused plugs out that had gaps of 0.060, measured. Putting new plugs in, gapped at the factory 0.045, I thought I'd see immediate mileage increase, but not even a tenth of a mpg.
The larger gaps stress the plugwire insulation more, so they don't work if your wires break down before the spark jumps. The spark will go somewhere, that's for sure.
I've used lots of plugs, Autolites seem to work well, Champions did too but tended to foul faster, I don't know why. But lots of races have been won with Champions. I've used Bosch Platinums, had some failures. I've used AC plugs, they don't seem to get much play around here, but they've been very good for me. Maybe because they're from (gasp) GM? But they worked reliably for quite a while.
R.
Re: 440 Tune Up
[Re: magic1]
#1646658
07/16/14 11:48 AM
07/16/14 11:48 AM
Posts: 12,244 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
How old is that MSD distributor? On a mild engine, we would often get well over 50,000 miles on caps and rotors. Especially if the cap had brass posts. Unless there are carbon tracking or other issues, they are not much of a wear item in normal driving circumstances.
Are the MSD cap terminals made of brass or aluminum? Brass is the only way to go, if available.
Champions or Autolites will be fine at .035 gap.
FireCore wires are the way to go.
If you want to go to the trouble, what RapidRobert suggests will be well worth the effort. Those adjustments are needed with today's excuse for gasoline.
Master, again and still
