If your axles where made to fit into the A body rear end housing and to use the stock type brakes with the big bolt pattern you should be good, if they where made to use with the B body brakes and backing plates use them
Years ago I went through this with Strange Engr., I had them make me a set of 35 spline axles to fit the stock A body housing with the stock brakes(there lighter than the other brakes on the E and B body cars
They used the B body axle blanks that have a larger outside diameter on the axle flanges so the stock A body 10x1 3/4 wide brake drums wouldn't it over those axles until I had the axle O.D. cut down to fit into the stock A body rear stock drums, $75.00 later
My message is you can make many things fit, as long as your willing to have them modified
My car ran in the low tens and high nines at or faster than 126 MPH with those rear brakes and the 1973 and later single caliper A body front discs
I never had a problem stopping that car at the races or anywhere else
