Re: Problem with my axle berrings
[Re: MidPenMopar]
#1646011
07/13/14 05:49 PM
07/13/14 05:49 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
if you are running an set of aftermarket rear disc brake set up like strange..wilwood...the green bearing are necessary....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1646012
07/13/14 05:52 PM
07/13/14 05:52 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Ok, but why would they only last a few thousand miles???
I did some reading and they said they are for racing only and not to be used for a street car??
Could they just have been a bad set??
[Re: bobby66]
#1646016
07/13/14 06:00 PM
07/13/14 06:00 PM
MidPenMopar
Did they remove the thrust block from the differential?
Dont know what that in unfortunately.
I bought the SSBC rear disc kit and for whatever reason they mandated the ball berring type and not the tapered type.
Would this be for some clearance issue on the axles maybe??
[Re: bobby66]
#1646019
07/13/14 06:52 PM
07/13/14 06:52 PM
RapidRobert
OK so with greens you do NOT want the thrust block in there?
[Re: MidPenMopar]
#1646022
07/13/14 08:11 PM
07/13/14 08:11 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
If the thrust block is present it may put a load on the bearings, pushing out on them and leading to premature failure.
Well now this is interesting.
Maybe that is the case??
More than likely the case , the only way around it is to cut your axles if you have a cone type sure grip because the only way to remove the thrust block from a cone type is to disassemble the sure grip.
[Re: MidPenMopar]
#1646029
07/21/14 10:46 PM
07/21/14 10:46 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Stu there are hundreds of thousands of Toyota pickup trucks out there with the same basic radial ball bearings as your "green" bearings and they live long tortured lives for over 100K. The first question I ask when setting up a rear is what kind of axle bearings are you going to use? Rollers get the spacer and ball bearings do not. I would really call the expert Cass (doctordiff) for your options on tapered roller bearings if you don't want to disassemble your differential. There may be a bearing retainer that you can shim like a Ford pickup uses to adjust the axle endplay. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1646030
07/21/14 10:56 PM
07/21/14 10:56 PM
MidPenMopar
Gus
My buddy who is doing the repair at his shop is going to use Ford roller bearings. And as now as the rear end is out i asked him to do a complete go through of all the other parts. I stopped by today and he showed me that the ring and pinion gears were fine but i also could use the bearings next to the sure grip replaced as well as they were showing some wear signs.
[Re: MidPenMopar]
#1646031
07/22/14 11:40 AM
07/22/14 11:40 AM
JohnRR
U.S.S.A.
Gus
You said it has a Crush washer ??? Do you mean thrust block ?
As far as the bearings needing to be replaced , they ALL need to be replaced and the reason is that POS cone type sure grip if that is what the car still has in it.
If he has the differential torn down have him put the solid spacer in place of the crush spacer on the pinion stem .
[Re: MidPenMopar]
#1646034
07/22/14 10:41 PM
07/22/14 10:41 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
Johm just hates cone types.Mine is the OE 69 and gets beat all the time.It still works perfect and no problems.Now if I ever replace it it will get the clutch type.Rocky
Chrysler Firepower
[Re: therocks]
#1646035
07/23/14 11:28 AM
07/23/14 11:28 AM
JohnRR
U.S.S.A.
I don't believe that you drive your car more than on and off a trailer
[Re: bobby66]
#1646037
07/23/14 02:09 PM
07/23/14 02:09 PM
therocks
Niles , Ohio
John at least I drive the thing.If you have anything that runs come on down in your ride and we will go crusing.Oh by the way it was a daily driver for at least 4 years after I installed it and that was in 71.Still going strong.That and for 35 bucks I cant complain as it was drum to drum.Rocky
Chrysler Firepower
[Re: MidPenMopar]
#1646040
07/25/14 10:32 PM
07/25/14 10:32 PM
MidPenMopar
Almost all back together but one of the bolts in the yoke snapped off inside so it was just easier and quicker to just go by a new yoke. Hope to have it all back on the road in a few days.
I take that back as the new pinion bearing went bad in the first few miles. So back apart again....
On a side note i did get an O2 sensor installed so the A / F mixture can be adjusted for optimum performance.
[Re: MidPenMopar]
#1646041
07/26/14 05:54 AM
07/26/14 05:54 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Ahhh... THE "Snowball" effect strikes again. I hate that. So often I start out on one thing but three other issues pop up requiring additional attention. Good luck my B body brother!
[Re: MidPenMopar]
#1646042
07/26/14 12:21 PM
07/26/14 12:21 PM
therocks
Niles , Ohio
Stu IIRC you have a 489 case.Unless you replace the crush sleeve it might eat another bearing.Thats why the sell an eliminator for it.You can set up the old one but its a pain.Removing the yoke you have to get the crush sleeve almost perfect to where it was.Rocky
Chrysler Firepower
[Re: therocks]
#1646043
07/26/14 08:53 PM
07/26/14 08:53 PM
Posts: 9,122 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
Rocky -
Tell me about the crush sleeve eliminator. I need to do a pinion seal on my 489 and have been putting it off because of the crush sleeve.
[Re: therocks]
#1646044
07/26/14 09:59 PM
07/26/14 09:59 PM
MidPenMopar
Rocky the the whole rear end came apart again and yes i got a new crush sleeve installed. Had the car back by 9:00PM last night and got to take it to a show today!
[Re: Ramrod39]
#1646045
07/27/14 11:41 AM
07/27/14 11:41 AM
therocks
Niles , Ohio
RamRod the crush eliminator dumps the crush sleeve.Its almost like it but the eliminator you can change the yoke like other rears.The rear has to come apart to change it.Dr Diff sells the eliminator.You can change the yoke with a crush sleeve.There is a explanation in factory manual on how to do it.Been years since Ive read it though.Rocky
Chrysler Firepower
[Re: Ramrod39]
#1646047
07/27/14 08:24 PM
07/27/14 08:24 PM
Challenger 1
Cincinnati, Ohio
Rocky -
A crush sleeve is a one time use collapsible spacer that helps set the pinion bearings preload. Once you disassemble it for a new anything, a new one must be used to achieve proper preload for the pinion bearings.
A solid pinion preload spacer can be used and is better, but it must be custom installed and turned down to the exact length needed for proper pre-load. This all needs to be done/setup with custom milled/turned pinion bearings that have oversize IDs so they slip on and off the pinion to determine pinion pre load spacer thickness. Can't use pressed fit bearing races on the pinion until you can/determine find proper pre load thickness. I have done it several times. So using and installing one(solid spacer,crush sleeve eliminator, etc) is not easy to install.
For a stock rebuild I'd use a fresh crush sleeve.
Here's what one looks like.
[Re: MidPenMopar]
#1646048
07/27/14 08:27 PM
07/27/14 08:27 PM
JohnRR
U.S.S.A.
Stu what brand is your A/F ratio meter ? I bought the latest Innovate Motorsports MTX-L and the instruction say the sensor needs to be 24 inches behind the end of the collector to get an accurate reading .
[Re: JohnRR]
#1646049
07/27/14 08:41 PM
07/27/14 08:41 PM
MidPenMopar
Yes the meter was run from the sensor up through the engine compartment and out the hood. Then into the interior where you can watch it as you drive.
Right now it was reading 13.00 to 13.55 when at freeway speeds but dropped to 11 to 12 at low speed. This will again need adjusting to help the low speed ratio.
Even not perfect the car ran 10 times better already! Keep in mind i also have a way to large cam profile that i am sure is hindering any low speed performance.
[Re: Challenger 1]
#1646051
07/28/14 01:07 AM
07/28/14 01:07 AM
Ramrod39
My New Title
My New Title
Tucson, AZ
Rocky -
So if a guy just needed to replace a leaking pinion seal on a 489 and wanted to keep it simple, what would you recommend?
[Re: MidPenMopar]
#1646052
07/28/14 02:34 AM
07/28/14 02:34 AM
JohnRR
U.S.S.A.
Sru I was talking about your sensor being mounted in the collector where it is , the directions should have told whomever installed that were to put it , the one I have the sensor needs to be mounted in the head pipe , not the header.
[Re: JohnRR]
#1646053
07/28/14 10:02 AM
07/28/14 10:02 AM
MidPenMopar
Ok John, i misread your question. When i see see my friend again i will ask why he mounted it there and not further back on the exhaust system.
