reground cam ,base circle too small now? #1646000
07/13/14 04:06 PM
07/13/14 04:06 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
So on advice from a friend I sent one of my hemi cam cores out to be reground locally as a copy of the comp thumpr hydraulic flat tappet.I opened up the box and they had to grind a ton on this cam the lobes are the smallest diameter I have ever seen ,is this even usuable? lift specs are 500 502 I believe and duration @50 is 228int and 241ex if i recall .....
Re: reground cam ,base circle too small now? [Re: ogopogo] #1646001
07/13/14 04:28 PM
07/13/14 04:28 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
cam looks fine. you will probably need longer pushrods though.
Re: reground cam ,base circle too small now? [Re: TS3303] #1646002
07/13/14 04:32 PM
07/13/14 04:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats what I think also.. its not into the base shaft
area so it hasnt reduce the strength yet.. and yes
on the push rods
Re: reground cam ,base circle too small now? [Re: MR_P_BODY] #1646003
07/13/14 05:33 PM
07/13/14 05:33 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
Ok thanks,i was worried I couldn't or shouldn't use it....Custom pushrods are a given on a hemi anyway so no problem there..
