Tell me about the P3690426 distributor
#164586
12/08/08 10:21 PM
12/08/08 10:21 PM
Posts: 8,143 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
A big block bud scored a P3690426 kit distributor http://store.summitracing.com/partde it appears to have the newer set up. So no more welding up the slots to limit the mechanical advance?
Re: Tell me about the P3690426 distributor
[Re: UCUDANT]
#164587
12/09/08 12:57 AM
12/09/08 12:57 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Yes and in fact the only BIG diff with stock unit is really the mechanical advance is now adjustable... rest is basically same dist
Being same dist than stock units then you are getting same new CHEAPY CHINA MADE INTERNAL COMMON REPLACEMENT PARTS like the reluctor and pickup coil, that does need to be adjusted/touched to get a propper "precision" parts.
I had to mill down every reluctor point to get the right gap... then BEND a little bit the pick up coil assembly to get a decent gap too on vacuum advanced position, and then readjusted again the gap on rest position... had to made that three times to get a good .007/.009 gap average in both positions.
If you only check gap on rest vacuum position, pretty sure coil will bite reluctor, because pickup coil movement IS NOT propportional with ratio againts center of dist
also milled down a little bit the pickup coil point to get a decent straight sensor point.
That's something you don't expect to make on a Mopar $180 unit, BUT HAVE TOO. If you don want, then spend double on an MSD ready to Run dist ( I mean with vacuum one ).. or maybe another aftermarket performance dist. Dunno if rest of dist options are more less with same issues. pretty sure MSD won't
[Re: dgc333]
#164589
12/11/08 01:59 AM
12/11/08 01:59 AM
NachoRT74
Valencia, España
how much time ago was that ?
I'm not against the stock parts used what I like a lot and in fact I want to keep the car "stockish" as posible, but just talking about quality and assembly precision... just giving my experience
