small block intake end gaskets or rtv? #1645148
07/11/14 01:35 AM
07/11/14 01:35 AM
Albuquerque, new mexico
moparvinson Offline OP
finishing up building a 318 for my sons 74 charger, on the intake manifold do you use the end gaskets or just rtv? I have heard both. thanks for any advice.
Re: small block intake end gaskets or rtv? [Re: moparvinson] #1645149
07/11/14 01:41 AM
07/11/14 01:41 AM
Mockup the intake with side gaskets only & see how much gap you have then if the front/rear gaskets are slightly taller then no problem useing them. If they are too tall it tends to cause water port leaks on the dr/pass front after time. If you use RTV clean the surfaces squeaky clean with brake kleen or similar and remove the dowel(s) & make sure the dowels dont interfere with anything.
Re: small block intake end gaskets or rtv? [Re: RapidRobert] #1645150
07/11/14 09:28 AM
07/11/14 09:28 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Mockup the intake with side gaskets only & see how much gap you have & make sure the dowels dont interfere with anything then if the front/rear gaskets are slightly taller then no problem useing them. If they are too tall it tends to cause water port leaks on the dr/pass front after time. If you use RTV clean the surfaces squeaky clean with brake kleen or similar and remove the dowel(s) & .
Fixed and
I like using the cork gaskets
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: small block intake end gaskets or rtv? [Re: Copper Dart] #1645151
07/11/14 11:12 PM
07/11/14 11:12 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
For what it's worth, my SB and my 426 Hemi intakes are both sealed with RTV front & back, and neither has so much as fogged the motor...sealed up tight.
Neither one needed to look 100% factory original, though.
With cork, I've learned to still place a blob of RTV at the corners.
Re: small block intake end gaskets or rtv? [Re: topside] #1645152
07/11/14 11:20 PM
07/11/14 11:20 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I use RTV and my Son uses cork gaskets and both ways work great. I set my manifold on first to see how much RTV is needed.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: small block intake end gaskets or rtv? [Re: moparvinson] #1645153
07/11/14 11:44 PM
07/11/14 11:44 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I'm an all r.t.v. guy. Self clearancing and can always be mad to fit.
Re: small block intake end gaskets or rtv? [Re: 67_Satellite] #1645154
07/12/14 12:32 AM
07/12/14 12:32 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I have a large stack of end gaskets,I'm waiting until they are worth big $$$ then I'll sell them. If someone wants a few dozen sets I'll take the actual shipping. If they don't sell soon I'll make earrings out of them.RTV all the way!
