Re: small block intake end gaskets or rtv?
[Re: moparvinson]
#1645149
07/11/14 01:41 AM
07/11/14 01:41 AM
RapidRobert
Mockup the intake with side gaskets only & see how much gap you have then if the front/rear gaskets are slightly taller then no problem useing them. If they are too tall it tends to cause water port leaks on the dr/pass front after time. If you use RTV clean the surfaces squeaky clean with brake kleen or similar and remove the dowel(s) & make sure the dowels dont interfere with anything.
