what disc brake setup fits my 70 challenger with drums #164470
12/08/08 08:25 PM
12/08/08 08:25 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
gonna upgrade it to disc soon dan
Re: what disc brake setup fits my 70 challenger with drums [Re: ph23vo] #164471
12/08/08 08:31 PM
12/08/08 08:31 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
1973-1976 Mopar A-body from the spindles outward is a direct bolt on.
Re: what disc brake setup fits my 70 challenger with drums [Re: ph23vo] #164472
12/08/08 09:25 PM
12/08/08 09:25 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
or you can use 73+ B, FJM, or R body spindles, which is what I'm using on my 71 Challenger.
1971 Challenger
Re: what disc brake setup fits my 70 challenger with drums [Re: cudazappa] #164473
12/08/08 09:33 PM
12/08/08 09:33 PM
Go to Wilwoods and save 20 pounds per front wheel. I did have front discs on my 72 Cuda from a 73 Dart Swinger.
Re: what disc brake setup fits my 70 challenger with drums #164474
12/09/08 10:42 AM
12/09/08 10:42 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
thanks guys car is all stock #,s matching so i want it to appear factory dan
Re: what disc brake setup fits my 70 challenger with drums [Re: rabid scott] #164475
12/09/08 11:54 AM
12/09/08 11:54 AM
Scott the above spindle will fit the 70 E uca/ball joint?
Re: what disc brake setup fits my 70 challenger with drums [Re: ph23vo] #164476
12/09/08 01:18 PM
12/09/08 01:18 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Earning every penny of that moderator paycheck.
DBAP
Re: what disc brake setup fits my 70 challenger with drums [Re: not_a_charger] #164477
12/09/08 08:20 PM
12/09/08 08:20 PM
BDW Offline
BDW  Offline
