rear brake rotors 06 Ram 2500 #1644376
07/09/14 01:14 AM
07/09/14 01:14 AM
md
mopars4ever Online content OP
mopars4ever  Online Content OP
md
I fought with trying to remove my rear brake rotor on my 06 ram 2500. I finally got it off after about 2 hours. I finished that side and I gave up for the day. Any advice before I go after the other side tomorrow.
Re: rear brake rotors 06 Ram 2500 [Re: mopars4ever] #1644377
07/09/14 07:01 AM
07/09/14 07:01 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Haven't looked that close at my 06 cummins yet, but I assume it has a drum in hat parking brake? Did you try to back off the parking brake setting so that the shoes don't catch on the rusty lip on the edge, this holding it up?
**Photobucket sucks**
Re: rear brake rotors 06 Ram 2500 [Re: 70Cuda383] #1644378
07/09/14 10:59 AM
07/09/14 10:59 AM
md
md
Yes, first thing I checked. The rotor was rusted on. I sprayed it with rust buster, pryed and beat on it till it came loose. I was just wondering if there were any tricks to getting it off.
Re: rear brake rotors 06 Ram 2500 [Re: mopars4ever] #1644379
07/09/14 12:44 PM
07/09/14 12:44 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Really no tricks.They just get stuck period.Some come right off some Ive actually broke the rotors getting them off.I used my SnapOn air hammer with a hammer tip on most.Just spray and work around the center.Some I even had to heat.then a good coating of antisieze on the hub before install.Just did a set of rear discs on my nephews.One fell off one was rusted on and a bear to get off.Also try prying on one side a bit while hitting the other side.That lets them pop off sometimes.I guess I dont have to tell you to remove the little factory clips that hold the rotors in place.Rocky
Chrysler Firepower
Re: rear brake rotors 06 Ram 2500 [Re: therocks] #1644380
07/09/14 05:53 PM
07/09/14 05:53 PM
md
md
Got it done. The other side was a little better. Thanks for the help.
