Re: Which 72-93 truck should I buy?
[Re: RODHALL]
#1644251
07/09/14 01:31 AM
07/09/14 01:31 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
88-93 would be my perfered years... here is why 1 88 start of the Cummins... 2 fuel injection on gas trucks. 3 NP241 on gas trucks NP205 on Cummins and 1 ton trucks... Body parts exchange on 81-93 trucks Less the 91-3 rad supports... 5 727 88 / A518 89up trans Cheep if needed rebuilds 6 Dana 60 fronts on CTD and most 1 tons... must have np205 gear drive transfer... 7 full door panels and headliners and trim, on most upgraded models.. * fuse box that don't melt or catch fire like on 76-80 trucks... 9 Not full time4x4... 72-80 trucks...
I think I hit most of it...
[Re: RODHALL]
#1644252
07/09/14 09:26 AM
07/09/14 09:26 AM
Posts: 1,030 NH
torredcuda
NH
I`m looking at 1/2 or preferably 3/4 ton but no 1 tons or Cummins so I guess my main concern for driveabilty would be the fulltime 4wd system. What exactly is the problem with the fulltime units and how hard it is to change over to a newer transfer case? Like I said 95% of my driving with it is local but I may do an occasional long haul to Lebanon Valley or even Carlisle which is 900 mile sround trip?
[Re: RODHALL]
#1644256
07/09/14 03:33 PM
07/09/14 03:33 PM
Guitar Jones
89 was the first year for a Cummins and the 89 to 91.5's had a non lockup 727 for an automatic with a 3.07 gear. Which means they had Dana 61 and 71 diffs. 91.5 to 93 had a non lockup 518 for the auto and 3.54 gears. The manuals from 89 to 93 all had the Getrag 360 5 speed with either 3.54s or 4.10s.
[Re: CTD5.9]
#1644258
07/09/14 11:19 PM
07/09/14 11:19 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
You need a front differential, a transfer case+linkage, then either a different transmission or at least the output shaft and tail section from a newer one. to swap over from full time. After that its just getting the driveshafts the right length. It's actually pretty easy if you have the parts, I've done it on a few trucks.
Someone please define full-time transfer case for me...???? I know my 73 W100's transfer case had 2-Hi, N, 4-Hi, 4-Low and factory lock-out hubs....to me this would not be considered full time...???? I purchased this truck brand new in 1973 .... scratches head
Rickster
[Re: RUNCHARGER]
#1644260
07/10/14 07:47 AM
07/10/14 07:47 AM
Posts: 1,295 Hawley, Texas
shinnery
super street
super street
Hawley, Texas
I have a 74 W-100 ClubCab SWB and it is a divorced transfer case part-time 4x4. AFAIK all 73-74 W-100s were divorced xfer case. Have a short tailshaft 727 and a short driveshaft back to the transfer case (NP205). They also have manual locker hubs on the front Dana 44. 5x5.5 bolt pattern wheels. And a rear 8 3/4 axle. Bryce
Every electronic device is manufactured with smoke stored deep inside...
only a true genius can find a way to set it free.
The most terrifying words in the English language are: "I'm from the government and I am here to help!"
[Re: shinnery]
#1644261
07/10/14 09:21 AM
07/10/14 09:21 AM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
Is an 80-84 front disc brake axle a bolt in for a 72-74 truck? I suppose you may have to swap master cylinders.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: RUNCHARGER]
#1644262
07/10/14 10:46 AM
07/10/14 10:46 AM
rickstershemi
Yours is a part time. The full time had a NP203 t-case and was always in 4wd, you could not unlock the front hubs as they spun all the time. Hiloc-Hi-N-Lo-Loloc. It had a chain in the T=case that wore out, small front wheel bearings that were ugly to change. Others may have different opinions but that is my thought on them. Your 73 is a tough truck too, it just has drums on the front rather than the discs on the 80 and up part timers. I really like the 72-80 body style so the 80 is a bit of a holy grail to me with it's great styling and Part time 4WD system. Nothing wrong with the 81 and up trucks either of course but I just like the early body styling more.
Sheldon
Thanks for the clarification Sheldon.....that 73 was a great truck....had it for over 10 years and never once gave me a problem....and it got worked hard
Rickster
[Re: Soopernaut]
#1644263
07/10/14 12:21 PM
07/10/14 12:21 PM
Posts: 760 Canada
CTD5.9
Canada
Yes other then the correct master cylinder it's a bolt in affair. Dodge didn't change very many dimensions until 94.
