who cnc ports heads? #1644225
07/08/14 08:06 PM
07/08/14 08:06 PM
Oil City PA
1baddart Offline OP
1baddart  Offline OP
Oil City PA
Looking to have my 440-1 heads cnc ported. I've called modern several times with no luck. Who else does it? What's the going rate for cnc porting?
Re: who cnc ports heads? [Re: 1baddart] #1644226
07/08/14 08:10 PM
07/08/14 08:10 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
IMO... Waiting to get ahold of Bob at Modern will be worth it.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: who cnc ports heads? [Re: B3422W5] #1644227
07/08/14 08:43 PM
07/08/14 08:43 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
I know modern is very busy, but he is very good.
I would try to PM Bob on here and keep trying to get a hold of him.
He was running a batch of big block heads, so he might be able to get you in?
Re: who cnc ports heads? [Re: HEMIDARTS] #1644228
07/09/14 12:00 AM
07/09/14 12:00 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Modern, or just go through Scott Brown, you can get him buyracingparts.com
Scott does all my heads intakes and cams, great results for me !
....BAD A$$ STREET CAR.....
Re: who cnc ports heads? [Re: n20mstr] #1644229
07/09/14 12:10 AM
07/09/14 12:10 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Doesn't Scott use Modern himself? I would just deal direct with Modern
1.41 best 60 foot
6.60 at 103.90 1/8
Re: who cnc ports heads? [Re: B3422W5] #1644230
07/09/14 12:15 AM
07/09/14 12:15 AM
N
n20mstr Offline
n20mstr  Offline
N
Yes he does, but I'm saying go through Scott is sometimes easier than dealing with modern. That's all, I consider my 440-1 to be the best ones I've seen, can't argue with 5.30's @ 132 , 3350lbs and a "street" roller cam from Scott.
Re: who cnc ports heads? [Re: B3422W5] #1644231
07/09/14 12:27 AM
07/09/14 12:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A lot of the engine guys in this area use Modern..
thats why he is hard to get in touch with(he is busy)
EDIT
He did my B1M/C heads(I should say his brother did
them before his passing)
Re: who cnc ports heads? [Re: MR_P_BODY] #1644232
07/09/14 10:15 AM
07/09/14 10:15 AM
Oil City PA
1baddart Offline OP
1baddart  Offline OP
Oil City PA
Thanks guys! I don't need them till spring so I'll keep trying to get in touch with them. I've heard a lot of good thing about modern that's y I really want them to get the work.
Re: who cnc ports heads? [Re: 1baddart] #1644233
07/09/14 11:04 AM
07/09/14 11:04 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
You might try email.............
MODERNCYL@aol.com
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: who cnc ports heads? [Re: Hemi Allstate] #1644234
07/09/14 11:34 AM
07/09/14 11:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
MODERNCYL@aol.com
Mark
Or PM him on here.... he usually sends back my PM
in a day or so... but I havent seen him on here lately
Re: who cnc ports heads? [Re: 1baddart] #1644235
07/09/14 12:09 PM
07/09/14 12:09 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Travis Knowlton (Knowlton Thunder Heads&Racing Engines) and Chuck Lofgren (Lofgren Auto Specialties) teamed up together awhile back. Travis is excellent, but busy too. I was very pleased with Travis' CNC work on some Gen 3 heads he did for me. I know he has CNC programs for Mopar B/RB stuff too.
If you like drag racing, support your local track.
Re: who cnc ports heads? [Re: n20mstr] #1644236
07/09/14 01:01 PM
07/09/14 01:01 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
That's how I do it. Never had a problem.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: who cnc ports heads? [Re: n20mstr] #1644237
07/09/14 01:18 PM
07/09/14 01:18 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Do you have flow data on those heads? I would like to see how they compare to my CNC 325s.
Re: who cnc ports heads? [Re: Airwoofer] #1644238
07/10/14 12:16 AM
07/10/14 12:16 AM
N
n20mstr Offline
n20mstr  Offline
N
Yes I have a flow sheet, says they go 385 on the intake on a 4.375 bore
Re: who cnc ports heads? [Re: 1baddart] #1644239
07/10/14 12:33 AM
07/10/14 12:33 AM
AndyF Offline
AndyF  Offline
Talk to the guys at Fastlane Machine in Orem, Utah. They got some of the CNC programs when Chapman went out of business. I've worked with them on a few heads and they are really good.
Re: who cnc ports heads? [Re: AndyF] #1644240
07/10/14 06:56 AM
07/10/14 06:56 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Anybody hear of, or use Heads up in Dayton Oh? They're a few miles away from Kammer&Kammer
**Photobucket sucks**
Re: who cnc ports heads? [Re: 1baddart] #1644241
07/10/14 10:59 AM
07/10/14 10:59 AM
ill
dennismopar73 Offline
ill
Question would be why?
How fast you running now?
How fast do you exspect to run ?
Are you just porting head no other changes?
Reson for asking i have seen stock heads run eddie jr run
Ported eddies run , and cnc ported jr heads run
In several combos from 474 motors to 540
In various cars wieghts
Dynos prove nothing to me as to many have known to be not reliable
As well as many flow benches
What i would rather see is some one that has actually taken thier heads
Take stock ones off run them. Put set of thier so call ported stuff
Make no other changes see what the actual pick up really is
in the real world
Re: who cnc ports heads? [Re: dennismopar73] #1644242
07/10/14 12:55 PM
07/10/14 12:55 PM
Oil City PA
1baddart Offline OP
1baddart  Offline OP
Oil City PA
This is a new combo. 572 Indy maxx block, custom bullet roller, I have as cast -1's I want ported. I know they're small but it's what I have.
Re: who cnc ports heads? [Re: 1baddart] #1644243
07/10/14 05:18 PM
07/10/14 05:18 PM
AndyF Offline
AndyF  Offline
Dwayne Porter does excellent work on Indy heads. He doesn't have a CNC but he gets good numbers. He'll also help you with a camshaft recommendation as well as other engine suggestions.
http://supercarraces.com/Porterracing.html
Re: who cnc ports heads? [Re: dennismopar73] #1644244
07/10/14 08:50 PM
07/10/14 08:50 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
in the real world
JAKES AUTOMOTIVE
