Re: Baseline carb suggestions for tunnel ram
[Re: MadMez]
#1644131
07/08/14 05:16 PM
07/08/14 05:16 PM
Posts: 43,225 Bend,OR USA
Cab_Burge
Make sure and get the same, identicle LIST number Holley carbs(IE 4779-1 or 4779 no dash or 4779-4 and so on ), verify all you can verify on both carbs. as far as idle air bleeds, high speed bleeds, start with the stock Holley jetting, power valves and squirters also to start with Tune from there, do the basic set up as far as the throttle settings on both carbs to match as far as the throttle blades are open and so on Make sure and check the throttle linkage travel and wide open throttle checks
[Re: MadMez]
#1644137
07/09/14 01:35 AM
07/09/14 01:35 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have the 750s. Carbs are expensive!
Being that you are gonna run the pair of 750s you can cut down on the squirters and jetting... your gonna need to test for YOUR driving style.. but I'd start at a 28-30 squirters and maybe 70s all around on jets but once you figure out the jetting then swap in a pair of PVs on the primary of both... this would be pretty close to where I would start... remember you have 2 carbs that basically draw half the air each
[Re: MadMez]
#1644138
07/09/14 11:48 AM
07/09/14 11:48 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I assumed that is why you are running the 750's , try trading them for something smaller if they don't work out ?
