New best 60' with my 8 3/4
#1643475
07/07/14 06:21 PM
07/07/14 06:21 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I went racing all last weekend and just cant get over how good the 60' times are for the setup. It ran 1.47 for the best and seems to just be working. The car has the stock type springs and used Rancho shocks that I just bought off of here and cheep monroe shocks up front, Pinion snubber. I leave off of a idle with the foot brake. The 8 3/4 has around 120 passes on it so I think I will open it up and check it out just to make sure everything is still good. I was also thinking maybe I should put the Mark Williams cap on it. Think the cap is worth it? I was maybe thinking of trying to add some more power.
67' charger 499 RB
10.57 at 127
Re: New best 60' with my 8 3/4
[Re: dragram440]
#1643476
07/07/14 06:32 PM
07/07/14 06:32 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I am sure you will find that everything looks fine up until it doesn't.
68 Barracuda Formula S 340
[Re: dragram440]
#1643477
07/07/14 06:46 PM
07/07/14 06:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The cap does help... but the pinion flex is what will kill it... on a heavy car you have greater friction on the tire and that causes more flex.. I've been running my alum center for about 9 years now(racing, not the time I've let the car sit).. it has some nice stuff in it but my car is light and its less apt to break this .. I had 600+ passes on my stock 8 3/4 with just a back brace till it spit the caps off(the caps went first but still due to flex on the pinion)
[Re: dragram440]
#1643481
07/07/14 07:23 PM
07/07/14 07:23 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Bullet proof? I would like to know what is bulletproof? Anyone on here ever break a dana 60 or a 9"? They all break at some point!
Noooooooooooo..........9" rears never break. BTW I went 1.38 one time with my 8 3/4.
[Re: Thumperdart]
#1643483
07/07/14 07:59 PM
07/07/14 07:59 PM
Posts: 4,071 Mo.
racerx
Mo.
Gotcha beat.............went two 1.36`s and 6.22`s back to back but I don`t race much.........
1 more I went 1.28's on my 8 3/4
[Re: Thumperdart]
#1643485
07/08/14 05:40 AM
07/08/14 05:40 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I made at least 250 1.50-1.56 with stock axles at 3100 lbs. in my 8.3/4. Just last year i drove my 78 cutlass to the track a few times & pulled off 1.72-1.73 60fts. with a worn out 7.5" rearend on big MT DRs. , It howled all the way there & back home, 110 mile round trip, the car weighs about 3400 lbs.
[Re: Thumperdart]
#1643486
07/08/14 07:49 AM
07/08/14 07:49 AM
MR_P_BODY
So much for that.............
I have a bunch of 1.19s on my 8 3/4.. I had a ton of 1.24s - 1.25s on the stock 8 3/4 with just a back brace
[Re: dragram440]
#1643491
07/08/14 06:07 PM
07/08/14 06:07 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I dont know what your car weighs, but Im sure its no liteweight. At best 3200 or so?? With your ET and 493, I think I would skip on the expense of the MW cap and the Machining that goes along with that and step up to a better rear axle. Apply the finances in a different direction IMO, Especially if your going to be adding some power to a already strong combo.
[Re: Thumperdart]
#1643494
07/08/14 06:28 PM
07/08/14 06:28 PM
dragram440
bigfork mn
My car certainly does not fly. I finally won my first round in eliminations last weekend, only took 3 1/2 years. I do have 35 spline axles, spool, back brace, and with 3.91 gears I get a good contact patch from the ring to the pinion. I do have a 742 carrier. Are there any benifits from carrier to carrier?
67' charger 499 RB
10.57 at 127
