Best valley pan #1643143
07/06/14 11:53 PM
07/06/14 11:53 PM
Ontario, Canada
Hyper Henry Offline OP
Ontario, Canada
Running a 2pc sheet metal valley pan and leaks oil no matter what I try. What are my best options to prevent leaks?? Running CNC'd max wedge ported Edelbrocks and a Indy tunnel ram.
Derrick
Re: Best valley pan [Re: Hyper Henry] #1643144
07/07/14 08:59 AM
07/07/14 08:59 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Derrick I found the stock bath and paper gaskets both sides worked the best when I ran eddies and a tunnel. They were not MW though so you would have some triming to do on the ports. Not sure if you run a low deck or tall but I have an indy 2 piece low deck valley cover you can try. It doesnt work with my B-1s.
Mark
