I posted this in resto but thought may get an answer here first.
Need some guidance before I break something
Had an issue with the wipers so looking into it the arm that goes from the wiper motor to the pivot on the drivers side wiper arm came off on the driver wiper side. In my quest to try and get it back on I took off the arm at the wiper motor also and thats when the issue started. When trying to figure out how to get the arm back on it does not seem to fit no matter which way I try and put it on (yea I goofed and didn't pay attention on how it came off). So is there only one way to make it fit and work? If I do get it on both ends it only goes one revolution and them jams up as it's trying to push the arm down into the cowl. I'm totally confused and is the wiper motor to continue to run counterclockwise all the time?
Thanks for any help ----
Russ
