Went to adjust worm gear pre-load........ #1642730
07/06/14 02:37 AM
07/06/14 02:37 AM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
went to check the pre-load on a '68 Dodge Dart manual and my lock runs into the pot coupling.
There seems to be a lot of thread on the nut compared to my '94 Dodge Ram.
Re: Went to adjust worm gear pre-load........ [Re: Moe] #1642731
07/06/14 04:02 AM
07/06/14 04:02 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I'm not sure of what you are trying to relay. Care to give it another try?
Re: Went to adjust worm gear pre-load........ [Re: Moe] #1642732
07/06/14 04:51 PM
07/06/14 04:51 PM
since you ain't getting much love on this deal I'll ask if the splined nub is too short/recessed to where the coupler is down too close to the box (adjuster) which I have never seen. Is the coupler down too far on the splined nub? It only goes down to where you can slide a lock bolt in sideways past the scallop to lock the coupler in position fore/aft. EDIT I see you do have the locking roll pin in there so...
Re: Went to adjust worm gear pre-load........ [Re: RapidRobert] #1642733
07/08/14 07:32 AM
07/08/14 07:32 AM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
If I punch out the roll pin and slide the pot coupling back will that give me enough room?
Re: Went to adjust worm gear pre-load........ [Re: Moe] #1642734
07/08/14 11:34 AM
07/08/14 11:34 AM
there's 2 sections of splines with a scallop in between them which to visualize the "scallop" that it'd be like if you took a rattail file & filed a groove on a round shaft. This is what the sideways roll pin goes past so as to lock the coupler in it's fore/aft position. yes I'd drive out the roll pin & slide the coupler back up the shaft toward the firewall so you can see if everything is copacetic there. In the pic it sure looks like there are protrusions from the adjuster face that are interfering with the coupler but I'm thinking that is just camera distorsion. Holler back
Re: Went to adjust worm gear pre-load........ [Re: Moe] #1642735
07/08/14 11:45 PM
07/08/14 11:45 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I'm still not getting your point.
The adjustment for the box is on TOP, the coupler is nowhere near the adjuster.
Re: Went to adjust worm gear pre-load........ [Re: Moe] #1642736
07/09/14 12:19 AM
07/09/14 12:19 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
loosen the jam nut on top of the box and turn in adjuster to tighten the box.
MLR426
Re: Went to adjust worm gear pre-load........ [Re: MLR426] #1642737
07/09/14 01:44 AM
07/09/14 01:44 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Thats exactly what I do. Not sure if the OP is on the same page though.
Re: Went to adjust worm gear pre-load........ [Re: Kern Dog] #1642738
07/09/14 11:54 AM
07/09/14 11:54 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Guys look at the photo. That big stamped steel nut is a lock nut, the piece that the shaft runs through is an adjuster, it uses a spanner wrench.
Re: Went to adjust worm gear pre-load........ [Re: justinp61] #1642739
07/10/14 10:34 AM
07/10/14 10:34 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Re: Went to adjust worm gear pre-load........ [Re: Kern Dog] #1642740
07/10/14 10:02 PM
07/10/14 10:02 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I do apologize. I am both humbled and impressed at the same time.
Thank you. I'm always willimg to learn. Sorry that I misunderstood you.
Re: Went to adjust worm gear pre-load........ [Re: Kern Dog] #1642741
07/20/14 03:47 PM
07/20/14 03:47 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
Thank You Commando1. The worm gear preload is the 'big' one if I'm not mistaken. The 'over center' or 'cross shaft' adjustment never did much for me. Turn it in too much and steering will bind. In other words coming out of a turn, the wheel won't return be itself. It will need minor input. (this is in way too far).
Re: Went to adjust worm gear pre-load........ [Re: Moe] #1642742
07/20/14 03:57 PM
07/20/14 03:57 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
Before I drive out the roll pin and move the coupler out of the way am I going to be able to clean-up this amount of 'play' or look into a new steering gear? Video
http://youtu.be/B8mxxq4OTmE
