10.13 trans brake: 10.14 footbrake #1642323
07/05/14 08:33 PM
07/05/14 08:33 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
Still can't find my spot on the tree bottom bulb racing using the trans brake so I tried foot braking my second time trial today. I thought for sure it would slow me down a good bit so i was presently surprised it ran about the same. My light was still RED but it was a step closer to green. We shall see how eliminations go.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 10.13 trans brake: 10.14 footbrake [Re: pittsburghracer] #1642324
07/06/14 12:47 AM
07/06/14 12:47 AM
Locomotion Offline
Locomotion  Offline
Trans brake vs footbrake results have a lot to do how the carb is set up.
Can you let some air out of the front tires to slow RT's?
Re: 10.13 trans brake: 10.14 footbrake [Re: Locomotion] #1642325
07/06/14 01:54 AM
07/06/14 01:54 AM
PA.
"Little"John
"Little"John
PA.
I gotta try something but I think I need a short break from racing for a week or two. We have a divisional next week at PRP so I'll sit and do some maintenance. Front tire pressure is 42 pounds right now. At 2500 I redlight and at 1500 I'm late but still a 1.41 sixty foot with a powerglide so that's still pretty good. I got to get out of racing mode and become a test n tuner if I want this to work. Or give up and put the box back in. OLD habits are hard to break at my age.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 10.13 trans brake: 10.14 footbrake [Re: pittsburghracer] #1642326
07/06/14 04:40 AM
07/06/14 04:40 AM
norcal
JLaSalle Offline
JLaSalle  Offline
norcal
Still going red with a long throw adjustable button?
1967 Coronet R/T
9.83 134mph. 470 cid st.6 heads
10x pro et track champion
Re: 10.13 trans brake: 10.14 footbrake [Re: JLaSalle] #1642327
07/06/14 07:43 AM
07/06/14 07:43 AM
PA.
"Little"John
"Little"John
PA.
No I bought the morosso semi-adjustable button. I think its more me than the button after what I guess would be around 20 years of top bulb racing.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
