hit the brakes hard and lost drive and reverse on 46rh #1641990
07/04/14 06:02 PM
07/04/14 06:02 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
A good friend has been nursing a 95 Ram 2500 CTD back to life. The transmission was glued together was what appeared to be a mix of burned motor oil residue and weasel snot. We went completely through the transmission and got it running again. Due to the contamination we fully disassembled the valve body to remove the caked on goo inside it. The two solenoids were replaced as well.
The transmission only has a handful of miles on it since the rebuild.
Yesterday, he took the truck out and everything was operating normally. He commented on it's smooth shifting. During the drive he had to brake abruptly. After that event he lost drive and reverse. The truck only runs in low and second gear now.
He's bringing it over tomorrow so we can put it in my shop and check it out.
Other than something screwy happening with the linkage what could be causing this condition?
My first thought was something in the valve body preventing the front clutch from engaging.
Where would you guys suggest looking?
- Stu Harmon
Re: hit the brakes hard and lost drive and reverse on 46rh [Re: feets] #1641991
07/04/14 06:36 PM
07/04/14 06:36 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Maybe the brake light switch didn't allow the TCC to unlock and it sent a shock through the trans?
Re: hit the brakes hard and lost drive and reverse on 46rh [Re: feets] #1641992
07/04/14 07:07 PM
07/04/14 07:07 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Ok off topic, but what got into or was put in the trans to contaminate it? Why?
Did a water get in it from a cooler line?
Re: hit the brakes hard and lost drive and reverse on 46rh [Re: autoxcuda] #1641993
07/04/14 08:37 PM
07/04/14 08:37 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
No clue. It was purchased with a bad transmission. I towed it home for him.
We went through the transmission and replaced every wear part and seal. The cooler lines were replaced as was the cooler itself. The heat exchanged on the engine was thoroughly flushed.
The new transmission fluid is still clean.
Here's a pic showing what the planetaries looked like before and after cleaning.
- Stu Harmon
Re: hit the brakes hard and lost drive and reverse on 46rh [Re: feets] #1641994
07/04/14 09:50 PM
07/04/14 09:50 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Is this trans basically stock or is it modified any ? The front clutch is on in both drive and reverse so a problem in the front clutch could be cause. Reverse also needs the L/R band but you dont need the band for first in a stock trans as the overrunning clutch (sprag) will hold in first. So it would still have first in even if the L/R band had a problem but no reverse. Just off the top of my head ts seems it has a problem of the front clutch not working. I cant think of hard braking causing a problem in the front clutch ? Ron
I realize I forgot this is an overdrive trans as it could also have a problem in the overdrive unit but I cant think of what would cause both reverse and first to be lost. If the direct clutches had a problem it can cause a reverse problem but the overrunning clutch in the overdrive would hold for first to work. Did you replace the complete overdrive unit or repair it ? Ron
Re: hit the brakes hard and lost drive and reverse on 46rh [Re: 383man] #1641995
07/05/14 11:44 AM
07/05/14 11:44 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The transmission is a stock type rebuild. The truck is destined to be a parts runner.
- Stu Harmon
Re: hit the brakes hard and lost drive and reverse on 46rh [Re: feets] #1641996
07/06/14 03:20 AM
07/06/14 03:20 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
We dropped the valve body for inspection. The 1-2 valve was sticking. It required a bit of effort to get that thing out. I cleaned the valve with lint free towels and scrubbed the bore with a soft bristled brush. It glides wonderfully now.
The transmission has 49 miles on it since the rebuild. 14 of them were after it lost reverse and third.
The fluid looked okay but there was some glitter in the pan. The magnet was a bit fuzzy but not frightening. The screens on the solenoids had collected a minor bit of stuff too.
Shooting a little air into the servo ports showed good function (as expected) but should there be a reaction when lofting a bit of air pressure in the clutch ports?
Being out of ideas, we buttoned it back up tonight. We'll toss in the fluid tomorrow and see if it's functioning properly. If not, we'll jack up the rear end and check pressures at the ports. Didn't think about that today until after we opened it.
Still open for suggestions on this one.
- Stu Harmon
Re: hit the brakes hard and lost drive and reverse on 46rh [Re: feets] #1641997
07/06/14 03:31 PM
07/06/14 03:31 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Still no go. The truck doesn't have reverse. In drive it only runs 1st gear. Manual second and first work.
He got fed up with it and threw in the towel. It's going to a transmission shop on Monday.
- Stu Harmon
Re: hit the brakes hard and lost drive and reverse on 46rh [Re: feets] #1641998
07/07/14 01:10 AM
07/07/14 01:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Some fuzz in the pan is normal , but after 49 miles ?
Putting air in the clutch ports will make the clutches apply.
Re: hit the brakes hard and lost drive and reverse on 46rh [Re: JohnRR] #1641999
07/07/14 02:53 PM
07/07/14 02:53 PM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
btw that truck should have a 47re.
Re: hit the brakes hard and lost drive and reverse on 46rh [Re: ditchdrift] #1642000
07/16/14 08:14 PM
07/16/14 08:14 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
It's a 47RH. Three wire plug on the side of the case.
The update:
A transmission shop took it apart to find out that we dumped the stuff in the front drum backwards. It ate the drum.
I guess that's what we get for working too late into the night on this kind of stuff.
- Stu Harmon
Re: hit the brakes hard and lost drive and reverse on 46rh [Re: feets] #1642001
07/16/14 08:58 PM
07/16/14 08:58 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Glad to hear the problem has been found. I hate to hear of components (or entire vehicles) being tossed for no real good reason. Keep on truckin'...
