Did Moroso make a mistake with this Trans. catch can #1641923
07/04/14 01:14 PM
07/04/14 01:14 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I needed a catch can for my new Transmission so I ordered this one from Moroso. It looks to be different from their old style petcocks and inlet. Old one entered through the side and this one enters from the bottom.
With the valve closed no fluid can get into the can and with it open, it won't hold any fluid. Did Moroso make a mistke with this. I can't see how this could work.
Re: Did Moroso make a mistake with this Trans. catch can [Re: Sammy] #1641924
07/04/14 01:25 PM
07/04/14 01:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
2 things... does it have a vent on the top and why close
the valve.. if its above the vent port it will drain back
in so you dont need to drain it
Re: Did Moroso make a mistake with this Trans. catch can [Re: Sammy] #1641925
07/04/14 01:26 PM
07/04/14 01:26 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Mabe to let the trany fluid return back into the transmission?
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Did Moroso make a mistake with this Trans. catch can [Re: MR_P_BODY] #1641926
07/04/14 01:31 PM
07/04/14 01:31 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
My son's car has the old style one and it enters from the side with the valve closed. Open up the petcock and it drains out.
And yes there's a 1/8"npt screen vent on top.
Good point about keeping petcock open but it defeats the purpose of having a catch can.
Re: Did Moroso make a mistake with this Trans. catch can [Re: Sammy] #1641927
07/04/14 01:35 PM
07/04/14 01:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not at all... then its a drain back reservoir and
it takes care of itself
Re: Did Moroso make a mistake with this Trans. catch can [Re: MR_P_BODY] #1641928
07/04/14 01:40 PM
07/04/14 01:40 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Here's my son's catch can and it has the same part #
Re: Did Moroso make a mistake with this Trans. catch can [Re: Sammy] #1641929
07/04/14 01:49 PM
07/04/14 01:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The one you show for your sons car is more for a radiator
but the can is mounted lower.. then it needs the drain
and it would trap over flow.. but on your trans you
can mount it above the vent port and let it self drain
and you wont have to ever mess with it
Re: Did Moroso make a mistake with this Trans. catch can [Re: MR_P_BODY] #1641930
07/04/14 02:05 PM
07/04/14 02:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
No they did not make a mistake. If anything they improved the design of that can. It is to allow the fluid to drain back into the the transmission pan. Mount it higher than the vent on the trans, leave the valve open and allow it to work the way it is designed to.
Re: Did Moroso make a mistake with this Trans. catch can [Re: Al_Alguire] #1641931
07/04/14 06:29 PM
07/04/14 06:29 PM
Lehigh Acres, Florida
rickstershemi Offline
Transmission Expansion Tank....Good Idea.
The catch can on my glide never had a drop in it...???
Rickster
Re: Did Moroso make a mistake with this Trans. catch can [Re: Al_Alguire] #1641932
07/04/14 07:54 PM
07/04/14 07:54 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I made my own from an aluminum water bottle from the 99 cent store. Mounted way up inside right fender and installed hose fitting on bottom and vented up top. No valve. Any fluid that enters, drains back automatically. Don't have to worry bout draining tank or low fluid in trans. I forget it's there and no more leaky vent at the big end.
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Did Moroso make a mistake with this Trans. catch can [Re: MoParFish] #1641933
07/04/14 08:12 PM
07/04/14 08:12 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Then why have a on/off valve at all on there? It seems if the valve is off, no fluid can enter and you transmission case isn't vented at all.
Re: Did Moroso make a mistake with this Trans. catch can [Re: Sammy] #1641934
07/04/14 08:24 PM
07/04/14 08:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you dont want the valve.. take it out and screw
a hose fitting in.. people use that tank for multiple
things and some might need the valve
Re: Did Moroso make a mistake with this Trans. catch can [Re: MR_P_BODY] #1641935
07/05/14 04:29 AM
07/05/14 04:29 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Guys that run a "chiller" on their trans between rounds and flush fluid through the system, need to be able to close that valve so that it doesn't push fluid out the vent while chilling it.
Monte
Re: Did Moroso make a mistake with this Trans. catch can [Re: MoParFish] #1641936
07/05/14 07:50 AM
07/05/14 07:50 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I made own as well from a part out of an air cond unit. I just clamped a filter on one end to make it look tidy. like yours the fluid is self draining.
