Crush Can - Learn Something new everyday #1641646
07/03/14 09:47 AM
07/03/14 09:47 AM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
Funny, I always thought the crush cans were all the same height.
I guess I was wrong...the shortest one is off my Cuda...the other two are off steering columns I have purchased.
Any ideas why the different heights???
Jason
Re: Crush Can - Learn Something new everyday [Re: CUDAJAS] #1641647
07/03/14 10:31 AM
07/03/14 10:31 AM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Did someone crush them!!!
Re: Crush Can - Learn Something new everyday [Re: hemirdrnnr] #1641648
07/03/14 10:52 AM
07/03/14 10:52 AM
MD
floyd Offline
floyd  Offline
MD
are there three different heights there? Hard to tell with the two taller ones.
Re: Crush Can - Learn Something new everyday [Re: floyd] #1641649
07/03/14 11:46 AM
07/03/14 11:46 AM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Yep the middle one is slightly shorter then the one on the left.
Jason
Re: Crush Can - Learn Something new everyday [Re: CUDAJAS] #1641650
07/04/14 11:21 AM
07/04/14 11:21 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
do you find stamped PNs on them ?
Re: Crush Can - Learn Something new everyday [Re: CUDAJAS] #1641651
07/04/14 11:27 AM
07/04/14 11:27 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Maybe out of wrecked cars.
Re: Crush Can - Learn Something new everyday [Re: CUDAJAS] #1641652
07/04/14 12:59 PM
07/04/14 12:59 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Maybe someone used a steering wheel puller incorrectly and stretched it.
Carl Kessel
Re: Crush Can - Learn Something new everyday [Re: NachoRT74] #1641653
07/06/14 01:47 AM
07/06/14 01:47 AM
CUDAJAS Offline OP
CUDAJAS  Offline OP
yep...sure did...all three are different.
shortest
other two:
Re: Crush Can - Learn Something new everyday [Re: CKessel] #1641654
07/06/14 02:01 AM
07/06/14 02:01 AM
CUDAJAS Offline OP
CUDAJAS  Offline OP
I think that is what happened.
The main difference I have noticed is that the height of the bottom of the can, the taller can starts out taller at the bottom.
There are the same amount of ribs on each can, but the ribbed sections are different heights.
It does not look like the small can has been crushed, no visible damage / compression inside the ribbed area.
However, I did notice a difference bottom of the cans. The two taller ones the bottom seems to be pushed out, while th taler can, the bottoms seems to be flat. Not sure if it will show up in pictures...but lets try.
Taller can, from underneath:
the rusty area under the horn ring is not flat.
the area under the horn ring is flat.
not sure what any of this means...but I think I will use the shorted one on my car.
Jason
