If you were to build a Big Block Wedge......
#1641038
07/02/14 01:09 PM
07/02/14 01:09 PM
Posts: 503 Idaho
1320Dart
Idaho
If you were to build a Big Block Wedge to go drag racing, What would you build, and how? You also don't have unlimited funds. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Greg ----------------------------------------------------------------- Cost is irrelevant, making memories is far more valuable!
Re: If you were to build a Big Block Wedge......
[Re: 1320Dart]
#1641042
07/02/14 02:15 PM
07/02/14 02:15 PM
Triple Threat
Renton Washington
You still need to be a little more specific. Many people build stock block big blocks that make 600hp, others making 900+. Any of these could be considered drag racing engines, but are drastically different.
Goals and budget... 8's, 9's, 10's?
[Re: 1320Dart]
#1641044
07/02/14 02:18 PM
07/02/14 02:18 PM
Posts: 345 Nebraska
451Cuda
Nebraska
What parts do you have now ?
I mainly wanted to hear the general consensus of what the guru's on here would build and use.(I know there are quite a few guru's on here)![](/ubbthreads/images/graemlins/bow.gif)
Parts I have; Heads, Block on order, Rods, Crank(but wanted to use a different one if budget allowed), Pistons and cam are on hold. Waiting on other info and the block before ordering those. I have many other parts to get it finished up.
I could be going the wrong way with my attempt. So I started this post to be a fly on the wall and learn a thing or two
Be more specific...which heads, any porting done? Which block/crank/rods? Intended purpose? Vehicle it will go into? Weight? Trans? Chassis? Is E85 available in your area?
[Re: Al_Alguire]
#1641046
07/02/14 02:25 PM
07/02/14 02:25 PM
Posts: 503 Idaho
1320Dart
Idaho
Well I do not have unlimited funds for sure. But question number one had better be what is my budget? Next what is my goal? I have had plenty of engines over the years and those are the two most important questions you must answer before you start.
Well my engine in my car was not what it was supposed to be. I pretty much have to start over. I've sold the motor already. I'm in pretty deep and cant back out now. I'd love like hell to be 8.0's. But like I've said before, I don't want to be inside this thing all the time. I know it can be done.
I wanted to mainly hear what you and the other Mopar guru's would build and how and what you'd use etc....
[Re: Mr.Yuck]
#1641049
07/02/14 02:59 PM
07/02/14 02:59 PM
Posts: 503 Idaho
1320Dart
Idaho
I guess it would depend on what it is going in and what your goals are.
[Re: 1320Dart]
#1641051
07/02/14 03:13 PM
07/02/14 03:13 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
That's a loaded question ![](/ubbthreads/images/graemlins/eeek.gif) We see many racers that build beyond their budget and abilities because they are never satisfied once they attain a certain level of performance.They never consider the cost of maintaince and repair at higher performance levels nor do they consider all the other related cost associated with the faster classes.The cost of maintaining and operating a 10 second car and a 8 second car are miles apart.As mentioned earlier get a solid plan of what you want to accomplish,plot the venture step by step as far as cost verses your budget.Remember to include any and all other factors besides the engine.Usually engine upgrade means chassis and driveline upgrades.The cost can sprial out of control. Most importantly know your skill and ability to be able to handle a faster car.Many get in over their heads find that they get a lesson they didn't intend on learning. What ever you do think it through before starting the project and good luck. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 1320Dart]
#1641053
07/02/14 03:28 PM
07/02/14 03:28 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Well still kinda open ended. I went 9.04 at 150 in a 3470lb 67 Valiant with a set of originals that flowed 415-420cfm with a stock block, Ohio crank, GRP rods, Indy oil pump and Bullet roller with 286/290 on a 113lsa with life at @800", unported single 4 intake and a out of the box Holley Dominator. Was a fairly budget minded build and in a 2800lb ish car would certainly run 8's with no issues. It was a father son project when my kid was still playing HS baseball so racing time was limited. We built the engine to get an idea on what would work well with plans to upgrade some components later to better pieces and more power. Made some cam and carb changes along the way and had a good handle on where to go with it. Ended up deciding to go super class racing instead after baseball and eventually sold the car. BTW if anyone in the Lincoln, NE area knows the car I would like try and get it back.
My point being some sort of budget it required to make some decisions on what direction lead. My advice is buy the best components you can afford. Running 8's at 2800lbbs is not rocket science. 900 hp will get you in the 8's easily. Your heads can support 950 relatively easy but if you want more you will either need to spin it harder or look for better heads. 950 in a great working car at sea level will net you sub 8.50 times. In Boise maybe 8.60's. FWIW my Barracuda at 2975 went 155 in Boise at the S/ST index of 11.15
[Re: Al_Alguire]
#1641057
07/02/14 03:54 PM
07/02/14 03:54 PM
Posts: 503 Idaho
1320Dart
Idaho
Hi Al! I know that your not a big fan of C.I. So knowing what you know and knowing the parts I have (mostly), what direction or build would you do? BTW I will be using carbureted alcohol FWIW.
