High-Amp Alternator #1640918
07/02/14 08:56 AM
07/02/14 08:56 AM
MD
Kevins493 Offline OP
MD
I have a '73 Challenger street/strip car that I've recently put an electric water pump, fan, and fuel pump on and the stock alternator can no longer keep up. I have already bypassed the bulkhead connecter with 6AWG wire with the appropriate fusible link. Is there a 100-Amp alternator being made (preferably something smaller like a Denso) that bolts in the same way and can use the stock wiring harnes. I'd prefer not to butcher the wiring to go to a 1-wire if I can help it. Thanks!
Re: High-Amp Alternator [Re: Kevins493] #1640919
07/02/14 02:12 PM
07/02/14 02:12 PM
Cab_Burge Online work
Cab_Burge  Online Work
Summit sells a 100 amp, Tuff something or other name brand, direct replacement alternator, they work good I put one(100 amp) on my Duster, they are powder coated black and flat work well IHTHs
Re: High-Amp Alternator [Re: Cab_Burge] #1640920
07/02/14 02:52 PM
07/02/14 02:52 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
I have a 120 amp denso alt that I think is for a late 80 early 90 doge van.pretty much a bolt on.but had to change the alt bracket spacers and had to change the field wire ends from a spade to a eyelet. Now Andy F makes alt mounting bracket kit for this alt that is very nice.mines been on my car for over 2 years and not have had any problems.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: High-Amp Alternator [Re: mopar65] #1640921
07/02/14 05:00 PM
07/02/14 05:00 PM
MD
MD
Thanks! How different is the mounting on the Denso? I run a Meziere water pump so I've made my own brackets to fit the stock alternator. Of course those problems would be eliminated if I go with the one CAB recommended. Any difference in power loss? Shame Summit doesn't stock the factory-style one in cast finish.
Re: High-Amp Alternator [Re: Kevins493] #1640922
07/02/14 05:08 PM
07/02/14 05:08 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Here is what I put on my stroker smallblock.
New Denso Alternator
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: High-Amp Alternator [Re: Kevins493] #1640923
07/02/14 05:28 PM
07/02/14 05:28 PM
mopar65 Offline
mopar65  Offline
The mounting points are the same as stock.I just had to make some new spacers.I am running the Mopar aluminum water pump housing.mines a big block.I couldn't really tell a power loss.but wasn't really looking.look at duster Dave's post.that is the same alt that I have.
Re: High-Amp Alternator [Re: mopar65] #1640924
07/02/14 05:40 PM
07/02/14 05:40 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I use nothing but CS130 GM 1 wires any more. just put this one on my van
http://www.ebay.com/itm/281353554869?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
on my hemi and there was one on my big block
Re: High-Amp Alternator [Re: Kevins493] #1640925
07/02/14 05:55 PM
07/02/14 05:55 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use a Tuff Stuff 100 amp alternator I got from Summit.I have the GM/Ford style case,as I have it attached to the motor plate.It works great.
Nautilus Racing-
Re: High-Amp Alternator [Re: Chris2581] #1640926
07/03/14 02:58 PM
07/03/14 02:58 PM
MD
MD
Thanks everyone!
Re: High-Amp Alternator [Re: sixpackgut] #1640927
07/03/14 03:11 PM
07/03/14 03:11 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I also use a GM CS130 but I do not use it in one wire form.
68 Barracuda Formula S 340
Re: High-Amp Alternator [Re: Kevins493] #1640928
07/03/14 03:36 PM
07/03/14 03:36 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
I'm daring myself to try one of these:
http://www.qualitypowerauto.com/catalog.php?item=557
Re: High-Amp Alternator [Re: Kevins493] #1640929
07/03/14 05:47 PM
07/03/14 05:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont buy any alt that I cant buy at the local parts
store.. that way if it dies on the road I can get one..
I've been running 85 amp denso on all of my junk..
even on my street Rampage with all the elec fan, pump,
fuel pump and head lights all on relays
Re: High-Amp Alternator [Re: MR_P_BODY] #1640930
07/03/14 11:18 PM
07/03/14 11:18 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
You won't notice a power loss unless you're at full change putting out 100 amps. Most of the time it will be 'free wheeling' under light load.
If it does go to full charge, I wouldn't image more than a 5hp loss, which you'd never feel on a butt dyno
**Photobucket sucks**
Re: High-Amp Alternator [Re: 70Cuda383] #1640931
07/04/14 08:02 AM
07/04/14 08:02 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I use a rewound CS140 with the heavy Duty diodes and remote voltage sensing that is hooked way back at the battery in the trunk.
It that basically bolts right in with a simple $30 bracket adapter. It puts out 115 amps at low idle and over 220 amps if it ever needed it at fast idle. It never puts out that much these days though, as I don't have the amp load without a stereo & amps.
You can get one out of an Escalade at a wrecking yard for cheap or at any of the auto parts houses.
Of course, I upgraded the rest of the electrical system using a modified MADD set-up.
Why? A/C, big electric fuel pump, the big twin Spal fans, electric windows, H4 relayed headlights, MSD and some day some decent music.
It almost even looks stock. No one ever notices it, or the A/C pump, mounted below it with the Bouchillon under alternator brackets and the re-routed belt drives to give significantly more belt to pulley wrap/contact.
I definitely would not hook this up to a stock or mildly modified Mopar wiring system without significant upgrades/mods. It uses a 2 gauge cable with a 250 amp fuse to feed my main power distribution lug under the hood. Then it's all big gauge cables, wires, fuses, and relays with quality Marine Grade wire fusing and related components from there.
Re: High-Amp Alternator [Re: 70Cuda383] #1640932
07/05/14 11:42 AM
07/05/14 11:42 AM
MD
MD
Thanks y'all! If the 85-amp denso will feed it, that's what i'll probably do. The current 65-amp unit is basically very marginal now so I'd rather not run it at 100% duty cycle. Mike definitely has a point about using one that you can get at any auto parts store.
Re: High-Amp Alternator [Re: Kevins493] #1640933
07/05/14 12:44 PM
07/05/14 12:44 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
Has anyone ever used a Altenator, or should I say be able to mount one while using a dry sump pump and vacuum pump with a motor plate I cant seem to find a place.
Re: High-Amp Alternator [Re: mokid] #1640934
07/05/14 01:58 PM
07/05/14 01:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my Rampage I mounted the alt on the frame rail
(tube chassis) and that opens up area.. on the race
car I ran a dry sump and alt.. I didnt need the vac
pump
Re: High-Amp Alternator [Re: MR_P_BODY] #1640935
07/05/14 05:18 PM
07/05/14 05:18 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
pump
That might just work, What about you A/C compressor ???? By the way got front strut/k-member repaired at Jerry Bickels back on track
Re: High-Amp Alternator [Re: mokid] #1640936
07/05/14 06:00 PM
07/05/14 06:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
pump
No A/C on my junk... 2 windows down at 80 mph
