engine valley hemi head studs? #1640850
07/01/14 11:24 PM
07/01/14 11:24 PM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
has anyone ever used loctite 290 green wicking sealant on the inner head studs after assembly to ensure a good seal into the intake runner? motor is smoking a bit and while i have it opened up i thought about applying this product to make sure no oil is being sucked into the runner from the studs. thoughts?
Re: engine valley hemi head studs? [Re: 3ddart] #1640851
07/02/14 01:42 AM
07/02/14 01:42 AM
Blue, red or green will work, the red and green are going to be a lot harder to remove from the heads if you ever need to work on them I use a regular thread sealer on them
Re: engine valley hemi head studs? [Re: Cab_Burge] #1640852
07/02/14 11:25 AM
07/02/14 11:25 AM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
As always, thanks Cab! Trying to get around pulling the heads (in an a-body and not sure this is the issue). With the green being a wicking compound, I was thinking of this as an"extra" insurance step since I have the intake off.
Re: engine valley hemi head studs? [Re: 3ddart] #1640853
07/02/14 01:37 PM
07/02/14 01:37 PM
Locktite(SP?) use to offer, maybe they still do, a wicking thread locker. I don't remember the color but the only green Locktite I know of now is the sleeve and bearing retainer product, I wouldn't use that on the studs
Re: engine valley hemi head studs? [Re: Cab_Burge] #1640854
07/02/14 03:21 PM
07/02/14 03:21 PM
malvern, ohio
3
3ddart Offline OP
3ddart  Offline OP
malvern, ohio
According to the loctite site 290 is green in color and is a medium grade thread locker and sealant (says it will seal porosity in welds) so as an insurance factor I think I'm going to give it a try. Like I said not even sure it's the issue, I'm just trying to cover all the possibilities. There was a wet (oil) spot on the intake gasket so a good possibility it was sucking oil in there. Thanks again, dave
