440 water pump housing question. #164052
12/07/08 10:33 PM
12/07/08 10:33 PM
pa
ramman16248 Offline OP
pa
my current 440 has the driver side exit on it right now. If I get a pasenger side exit housing, will my Alternator bracket and power steering pump still fit the same on the passenger exit as the driver side exit? Thanks, Jason
Re: 440 water pump housing question. [Re: ramman16248] #164053
12/07/08 11:32 PM
12/07/08 11:32 PM
yes
Re: 440 water pump housing question. [Re: RapidRobert] #164054
12/07/08 11:34 PM
12/07/08 11:34 PM
pa
pa
Thank you very much!!!!
Re: 440 water pump housing question. [Re: ramman16248] #164055
12/07/08 11:36 PM
12/07/08 11:36 PM
You're welcome. EDIT someone(I forget who) is now making an aluminum one(pass inlet). those iron ones weigh a ton.
Re: 440 water pump housing question. [Re: RapidRobert] #164056
12/08/08 12:12 AM
12/08/08 12:12 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
440Source - Part No: 200-1079
Ride eternal, shiny and chrome
Re: 440 water pump housing question. [Re: DirectSubjection] #164057
12/08/08 03:07 AM
12/08/08 03:07 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Be sure to set your timing first, after you change the housing the marks are covered up.
Re: 440 water pump housing question. [Re: DirectSubjection] #164058
12/08/08 08:08 AM
12/08/08 08:08 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
OMG! more chinese junk! run away! run away! don't buy their junk, it's made in china by kids getting paid pennies a day!
sorry...figured I would say it before someone else does.
I will be getting one of these so that I can use my custom serp belt set up that needs all the holes/bosses of the newer aluminum housings, and eliminate my lower hose from crossing over the front of the engine to work with my passenger side radiator.
Thank you Brandon for making this!
**Photobucket sucks**
Re: 440 water pump housing question. [Re: 70Cuda383] #164059
12/08/08 02:48 PM
12/08/08 02:48 PM
Indiana
P
Pentastar440 Offline
P
Indiana
Any radiator shop can move the lower neck from one side to the other on your radiator. It shouldn't cost much to have this done. Just tell them about where you want to move it to.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: 440 water pump housing question. [Re: ramman16248] #164060
12/11/08 10:18 PM
12/11/08 10:18 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
I've got an iron one for cheap! Can you say shipping only?
