Which shifter handle for Tremec conversion non-console? #1639909
06/28/14 08:18 PM
06/28/14 08:18 PM
Tennessee
Charger500 Offline OP
Tennessee
I have a 70 charger and noticed the handle provided in the kit hits the dash before engaging 1st, 3rd or 5th. It is a 12 inch shifter probably universal or Camaro design. I have a buddy seat and prefer to keep it. I noticed it with the initial mock up and was wondering if anyone else has had this issue and which handle you went with. I prefer a ball handle not pistol grip. Thanks.
Re: Which shifter handle for Tremec conversion non-console? [Re: Charger500] #1639910
06/29/14 12:30 AM
06/29/14 12:30 AM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
I just put a Tremec TKO-600 in my Dart and I used this lever:
http://www.summitracing.com/parts/lng-22613
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Which shifter handle for Tremec conversion non-console? [Re: Charger500] #1639911
06/29/14 12:56 PM
06/29/14 12:56 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Have you tried a 69 B body 4spd shifter (modified of course)?...Keisler used to offer a line of repro Mopar factory style shifters designed to fit the Tremecs, but with going out of business, that line may now be obsolete, unless the new owners of Keisler are going to continue offering them?...you may want to contact them www.shiftsst.com
An other alternative, although you don't like the pistol grip is a 70 Bench seat pistol grip (availablr repro from many sources) shifter, much easier to adapt to the Tremec shift nub...the shifter throws in the Tremec are radically shorter than the factory 4 spd
Mike
Here's the 69 B body style shifter for ball lovers
Re: Which shifter handle for Tremec conversion non-console? [Re: Charger500] #1639912
06/29/14 08:23 PM
06/29/14 08:23 PM
Kentucky
E
ewolfe Offline
ewolfe  Offline
E
Kentucky
I used the diagrams here http://www.hurst-shifters.com/stick-diagrams-shifter-assembly-diagrams-transmission-id-charts/ to find the perfect stick to fit my Dart with a bench seat.
